2000 Jetta TDI (Diesel!) FS/FT *SOLD* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2012, 01:55 PM   #1
greenzj
Cleanest 5.9L ZJ around
greenzj's Avatar
Default 2000 Jetta TDI (Diesel!) FS/FT *SOLD*
I have a 2000 Jetta TDI for sale or trade. I bought the car in August in Indiana with 187,xxx miles. 2 weeks after buying it, I had the car professionally detail. The very next day the engine ran away from me which resulted in a piston practically falling apart.
I took the car to a local shop that specializes in TDI's and had a lower mileage (134k miles) engine from a 2002 Beetle TDI automatic installed. Being that the engine was from an auto, it has the larger, highly sought after 11mm injection pump. This was a nice free upgrade that usually costs around $400 bucks alone, lol. At the same time as the engine swap I had a slew of new parts installed. Below is a list of all new parts.
This car is ready for anything you can throw at it. The clutch, head studs, motor mounts and injection pump make this car a perfect candidate for a high torque, high horsepower daily driver build. The clutch feels exactly the same as the stock clutch did, so you don't lose any daily driver comfort. I also deleted the EGR and vacuum reservoir while the engine swap was being done. I can provide receipts for the engine swap as well as all of the new parts.
-Southbend Stage II Endurance Clutch - $550
-IDParts Complete timing belt/water pump kit - $310
-ARP head studs - $145
-Black Forest Industries Stage 1 motor mounts(yellow) - $126
-cam seal - $8
-coolant neck and bolts - $10
-Thermostat - $19
-5mm vac hose - $14
-3mm vac hose - $15
-EGR block off plates - $20
-Exhaust gaskets - 10
-EGR delete hose - $20
-Rear main seal - $37
-5 speed transmission seals - $55
-2 hole head gasket - $30
-Dipstick tube - $8
-Driver side axle shaft(lifetime warranty) - $70
-Poly A-Arm bushings - $60
-Alignment - $75
-New Bosch MAF sensor- $120
After getting the car back on the road, I found a set of factory OEM GLI headlights and tail lights. The GLI headlights have factory installed fog lights, but the car was not wired for fog lights from the factory. I swapped the orange turn signal lenses inside the headlights for clear, and then I purchased a (Euro) headlight switch and a pre-made wiring harness from ECS tuning to take advantage of the fog lights. The fog lights function off the OEM headlight switch exactly as they would from the factory now. The headlights also have clear laminex installed on the lenses to prevent fogging. At the same time I was installing these headlights I painted the grill black with plastidip. It can easily be peeled off if the buyer would like.
I am asking $6900 obo. EDIT: New price is $5900 until the new car I want sells I am open to all kinds of trades. Just shoot me offers. I feel this is very fair considering the upgrades and maintenance done to the car since my ownership. this car is ready to go for years to come with no major maintainence needing done for at least 100k miles, at which point it will need a new timing belt again. It has all the base mods done if your wanting to upgrade the drivetrain for more power. If not you can keep it the way it is. I am currently averaging 48 mpg city the last two tanks and have gotten 56 mpg and 57 mpg highway on two 5 hour trips over the last two weeks. My cell is 4192960943. Please call or txt at any time if interested. Thanks!
On to the pictures!
On my way home from Indiana with my new TDI
Sitting on stands, waiting for the engine to be removed
[IMG]https://sphotos-a.xx.fbcdn.net/hphotos-
ash3/23895_10151106327001644_762552682_n.jpg[/IMG]
Old engine
Engine out!
New engine!
https://sphotos-a.xx.fbcdn.net/hphot...10357973_n.jpg
Piston of the old engine
New headlights (clear lense swap and installed)
old vs new
Plastidipped gril
greenzj is offline
Old November 16th, 2012, 01:56 PM   #2
greenzj
greenzj's Avatar
Also, I do have the passenger side lower grill assembly. Just been too lazy to remove the factory tow hook and reinstall it. I also forgot to mention it has 20% window tint that was professionally installed. Looks great!
greenzj is offline
Old November 16th, 2012, 02:32 PM   #3
drew454u
drew454u's Avatar
Why are you selling it? And not sure if i missed it but what's the current mileage on the car?
And problem areas? Dents? Rust?
Thanks.
drew454u is offline
Old November 16th, 2012, 02:40 PM   #4
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Why did the old engine run away?
RIP FULLSIZE4LIFE
SHARPMACHINE is offline
Old November 16th, 2012, 02:46 PM   #5
greenzj
greenzj's Avatar
Oil build up in the intercooler is our best guess. There was a lot of oil in the intercooler piping and the old intake manifold.
greenzj is offline
Old November 16th, 2012, 02:48 PM   #6
greenzj
greenzj's Avatar
Thanks.
Im just looking for something different. Its has your typical wear for a 13 year old vehicle. No major dents or scratches to report. There is one crack in the rub strip on the front bumper, and a strange hole about the size of a penny in the rear bumper. This car is incredibly clean and the paint shines like new. Current mileage is almost exactly 189900 as of today. It will continue to rise as I daily drive it. Should hit 190k by the end of next week
greenzj is offline
Old November 16th, 2012, 05:39 PM   #7
Seraphim Soldier
Always the hard way
Seraphim Soldier's Avatar
Meteor, we call this bein' in burger heaven!
Seraphim Soldier is offline
Old November 16th, 2012, 10:23 PM   #8
greenzj
greenzj's Avatar
Joe dirt bump! ^^^
greenzj is offline
Old November 16th, 2012, 10:32 PM   #9
dfm_13
dfm_13's Avatar
It puts the joe dirt in the hole
dfm_13 is offline
Old November 17th, 2012, 07:04 AM   #10
MARF75
Wanna fight?
How about you stick your head up my butt and fight for air
MARF75 is offline
Old November 18th, 2012, 01:05 AM   #11
moparhorse
moparhorse's Avatar
Wish I had the cash
moparhorse is offline
Old November 18th, 2012, 01:25 AM   #12
low900rr
low900rr's Avatar
Any interest in a ktm625smc
low900rr is offline
Old November 18th, 2012, 07:16 PM   #13
greenzj
greenzj's Avatar
Pm sent
greenzj is offline
Old November 19th, 2012, 10:22 AM   #14
Seraphim Soldier
Always the hard way
Bump for a super clean "I wish I could"
Old November 19th, 2012, 10:23 AM   #15
Seraphim Soldier
Always the hard way
Just for Shitsandgigs
Would you be interested in a trade?
2000 Wrangler 4.0 manual LOW MILES. ANOTHER PRICE DROP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2012, 07:12 PM   #16
greenzj
greenzj's Avatar
PM sent. Bump for a clean mk4 tdi!
greenzj is offline
Old November 21st, 2012, 08:43 AM   #17
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
any interest in the supercharged 454 K2500 suburban I have for sale on here?
xj_man_646 is offline
Old November 21st, 2012, 09:23 AM   #18
greenzj
greenzj's Avatar
Sorry, no thank you. Thanks for the offer though!
greenzj is offline
Old November 22nd, 2012, 04:15 PM   #19
Swerve
Swerve's Avatar
I may be interested, if you are. Here's what I have:
Swerve - Nissan Xterra Forum: Xterra Forums
Swerve is offline
Old November 24th, 2012, 04:17 PM   #20
68Scout
'68 Scout ~rebuilding
68Scout's Avatar
Not sure if you'd be interested in another VW, but I have a GTI that I am considering selling. http://grandrapids.craigslist.org/cto/3431899307.html
68Scout is offline
Page generated in 0.38335 seconds with 85 queries
