XJ no Heat! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2012, 12:02 PM   #1
krowen
Default XJ no Heat!
O.K. i have an 2000 xj, the engine temp runs normal but blows cold air , is there a heater valve somewhere? i blew air throught the heater core and it seems to have flow that way. i ran it a while this morning with it jacked up to try to get the air out if it had an air losck for some reason. Any ideas? thanks Kim
krowen is offline   Reply With Quote
Old November 16th, 2012, 12:06 PM   #2
89Laredo
89Laredo's Avatar
Send a message via Yahoo to 89Laredo
97+ doesn't have a heater control valve.
Maybe a stuck blend door?
Does you vent selection switch work properly?
All I want to do is smoke meth, fuck my sister, and hang myself with a belt.
89Laredo is offline   Reply With Quote
Old November 16th, 2012, 03:38 PM   #3
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
Mine 2000 XJ does the same thing, it doesn't blow cold air when the heat is on, but it just blows warm air. Nothing compaired to how hot my 99 XJ would blow out. Will change the cap and see if it makes a difference.
mudviper is offline   Reply With Quote
Old November 16th, 2012, 04:53 PM   #4
krowen
the cap is my next step, today i ran a garden hose through the heater core, got a little bit of black stuff out of it the nice clear water, switched and fed it back through the other way nice and clear. hooked everything back up and ran it and great heat, so i drove it to work tonight and on the way it went away again. ? i'm going to get a radiator cap tomorrow. Kim
Old November 17th, 2012, 01:44 AM   #5
krowen
up
Old November 17th, 2012, 04:16 AM   #6
XJsport95
Haters be my motivators!!
XJsport95's Avatar
I know this may sound dumb, but do you have enough coolent in the system? Also after you work on the lines did you try to get the air bubbles out of the system? My 95 XJ would slowly leak coolent and the system would only circulate in the main coolent line and not send any to the heater core. Just my. 02
XJsport95 is offline   Reply With Quote
Old November 17th, 2012, 06:17 PM   #7
krowen
well replaced the rad. cap today, had a little bit of heat for awhile on the way to work then dropped off again. tomorrow replace the t-stat! this is getting frustrating.
Old November 22nd, 2012, 10:37 AM   #8
2000ZR2
2000ZR2's Avatar
I had a 95 monte carlo doing that found a blown head gasket. No coolant in the oil ran fine but it was putting compression in the radiator. Get a radiator tester pressurize the system and see if it holds. Black stuff you found in the heater core possibly carbon!
2000ZR2 is offline   Reply With Quote
Old November 22nd, 2012, 07:11 PM   #9
krowen
Thanks, put a new t stat and water pump on it 2 days ago, drove it to west branch yesterday, seems o.k. for now. will see what it does when it gets cold this weekend.
Old November 22nd, 2012, 08:27 PM   #10
cj7on44's
cj7on44's's Avatar
i just had to replace the blower motor resistor in mine and now the heat works good
cj7on44's is offline   Reply With Quote
Old November 22nd, 2012, 08:29 PM   #11
amc78cj7
amc78cj7's Avatar
Our '96 XJ did the same thing. would blow only cold air. I replaced the heater blower motor resistor which goes through the firewall down near the blower and this fixed the problem. I think it's part #16 in the diagram below. The flat base of the resistor was diamond shaped. Seems counter intuitive since that electrical connector should turn the fan on and off (which was already working) but not control the thermostat for hot fluid flow. Nevertheless, it worked. I replaced the blower motor and fan while I was in there.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old November 22nd, 2012, 08:53 PM   #12
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
are both lines going to the fire wall hot, or is there a big difference in temp. ???
Old November 22nd, 2012, 09:27 PM   #13
krowen
so far they are hot now. i will know more in the morning on my way home from work. they were not both hot before.
Old November 25th, 2012, 04:34 PM   #14
Wehan
Wehan's Avatar
check that the heater hoses aren't collapsing when engine is above idle, had an old truck do this. replaced the hose and it was back to normal.
Wehan is offline   Reply With Quote
Old November 26th, 2012, 11:22 AM   #15
Miller 99
Miller 99's Avatar
Vacuum leak. Or the plug on the back of the heater face unit.
Miller 99 is offline   Reply With Quote
Old November 28th, 2012, 03:31 AM   #16
2000ZR2
2000ZR2's Avatar
Still working?
Old December 2nd, 2012, 06:21 AM   #17
krowen
still working! thanks for the help.
Old December 2nd, 2012, 07:54 AM   #18
aber61
aber61's Avatar
Being low on coolant can do that. Mine was not getting as hot. Sitting at a light it was ok and when i start driving down the road it would cool off which led me to think the coolant is low. I checked it and sure enough.
aber61 is offline   Reply With Quote
Old January 9th, 2013, 05:04 PM   #19
krowen
well back up again, blows some heat but not very much! any other suggestions? what would the blower moter resistor have to do with this problem? the motor seems to work fine!
Old January 10th, 2013, 08:06 AM   #20
lil_freak_66
Trolls off road club
lil_freak_66's Avatar
Send a message via MSN to lil_freak_66 Send a message via Yahoo to lil_freak_66 Send a message via Skype™ to lil_freak_66
on my 88 i swapped out the blower motor and the resistor pack.
$50 for both combined, 30ish for motor and 20 for resistor pack.
cheap enough to justify replacing both, and its easy enough to do even somebody as mechanically retarded as me to do without getting dirty in under an hour with just a screwdriver.
dont know if it would help since its blowing cold,dont know how it would help since im not really sure how it all works exactly...but with mine i was only working at lower fan speeds and it was cold, blows better than a half drunk paris hilton now! the plug into the back of the heater/ac controls was also loose and causing issues.
could your plug to the controls be loose/not in there all the way? if its blowing good but cold with it set on high it could not be getting told to switch to heat from air.
lil_freak_66 is offline   Reply With Quote
Page generated in 0.39734 seconds with 83 queries
