Mr. Beefy's "not quite yet U4 buggy" build - Page 49 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2013, 07:18 AM   #961
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Were you running the complete F250 brake system on the last rig? Nothing removed?
Reason I ask is because of the proportioning valve. Its the one item that you haven't stated you are using in the new setup that would have been in the old setup unless you removed it.
Without it the fluid and pressure gets split 50/50 between the front and rear calipers. Which would cause your issue.
NOT sent from an iPhone
Old June 7th, 2013, 07:21 AM   #962
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I was wondering the same thing.
I have the same problem you describe John. Started when I removed the proportioning valve.
I've just lived without breaks for the most part
Old June 7th, 2013, 07:26 AM   #963
bigblockford79
Big Block Ranger
If you want to borrow an adjustable prop valve to test this theory mine out of the truggy is just laying on the bench. That way you don't spend the $100 on one and find out you have another issue.
Shoot me a text if you want me to bring it with me tonight.
Old June 7th, 2013, 07:39 AM   #964
The master has a Brake Master Cylinder Fluid Control Valve on it. Attaches between the line and the master only for the rear brakes.
The bronco had the stock master from a 96 f250 1.250 bore, 03 ranger booster, and the stock pedal assembly from the 96 f250. And the same calipers in the rear as the buggy. Front calipers were 95 f350. Buggy fronts are 89 f350.
Old June 7th, 2013, 06:27 PM   #965
Thanks Gary
Since the plenum only came on 5.0s and either said explorer or 5.0 I had a new one made since mine is a 5.8L.
Old June 7th, 2013, 06:34 PM   #966
Tacker
Tacker's Avatar
Fawk Yeah! I love it!
Old June 7th, 2013, 06:35 PM   #967
Toyfish
Toyfish's Avatar
Thanks Gary
This is awesome!
Sent from my DROID X2 using Tapatalk 2
Old June 7th, 2013, 07:14 PM   #968
nd4spd71
nd4spd71's Avatar
nd4spd71 is offline   Reply With Quote
Old June 7th, 2013, 08:02 PM   #969
Originally Posted by nd4spd71 View Post
Old June 7th, 2013, 08:37 PM   #970
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I like it!
H.o.r.e
Old June 7th, 2013, 09:12 PM   #971
dreezy
Haggard Fab
dreezy's Avatar
Old June 8th, 2013, 10:48 AM   #972
Went and got a f250 pedal assembly (4:1) and installed the booster from the EB. Pedal travel is way better. But it doesn't feel like I have much power assist. So half way there lol. Gonna pick up new hose for booster as I don't like the hose I am using. Grab my timing light and vacumn gauge from work.
Old June 11th, 2013, 08:51 PM   #973
03 ranger booster - 92-97 f series pedal assembly - 1 1/8 92-97 master cylinder.
I now have brakes.
Its loaded and headed to Drummond tomorrow....
Old June 11th, 2013, 08:52 PM   #974
Need to get new fenders to trim them up better.
Old June 11th, 2013, 09:10 PM   #975
bigblockford79
Big Block Ranger
What time are you heading out in the morning.
Old June 11th, 2013, 09:14 PM   #976
chevotass
chevotass's Avatar
have fun!
Old June 11th, 2013, 09:25 PM   #977
7am
Were sleeping at als to get a head start in the a.m.
Old June 11th, 2013, 09:26 PM   #978
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
I am headed out about 6 Brandon
Old June 11th, 2013, 09:34 PM   #979
bigblockford79
Big Block Ranger
Ok, I am leaving work at 5am then heading to Meijer for some shopping. Should be heading north from 54th and US-131 by 6.
Old June 15th, 2013, 05:48 PM   #980
Time for chromos, broke the RF inner at turtle ridge.
But the buggy works and works well .
Page generated in 0.37191 seconds with 84 queries
