Mr. Beefy's "not quite yet U4 buggy" build - Page 47 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2013, 12:52 AM   #921
jbsjunk
Little Member
jbsjunk's Avatar
I see a trend happening. At least he's consistent.
Old June 1st, 2013, 05:49 AM   #922
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
That thing turned out sweet! I can't believe how quickly you built it!!!!
Old June 1st, 2013, 04:22 PM   #923
I can't believe how long it took .
Old June 1st, 2013, 04:26 PM   #924
Mounted front lights. Worked on cleaning up the electrical but ran out of wire. Redid front brake lines and hoses. Better, but think I am gonna end having to do the rear to.
Old June 1st, 2013, 05:17 PM   #925
nd4spd71
nd4spd71's Avatar
nd4spd71 is offline   Reply With Quote
Old June 1st, 2013, 07:58 PM   #926
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Nice !
Old June 2nd, 2013, 08:32 AM   #927
Originally Posted by Bones View Post
what MC do you have? You have to watch the pressure ratings with assisted or boosted MCs
Stock booster.
Early Corvette MC. (don't recall exact one)
I have never blown a line standing on the brakes hard. (sorta ) I did blow one of JohnnyJ's while at KOH. We had the brakes locked with the shutoffs off during his pitman arm repair. I hopped in to drive it on down the hill & no one remembered that we needed to turn the brakes back on. I started to roll and stabbed the brakes, blowing a line. But, that's in a deadheaded situation.
Old June 2nd, 2013, 03:39 PM   #928
Rewired the dash on the buggy, wired in the headlights, installed another small relay box to run the headlights donated from the part out explorer. Also was really nice that I kept the oe body harness from that explorer. With all the various wire codes and gauge of wires it made it real cheap and easy to rewire things as I could easily separate things and wire accordingly.
Looked over the buggy closer from last weekend, Sarah did manage to smash the inside lip of the RF rim. Has a pretty huge dent in the bead area. Surprised its not hitting the caliper as it goes round and round. Also I apparently didn't give enough clearance of the front driveshaft and exhaust. At one point while she was driving I thought I heard something rubbing. At least I found it. I also wired in my front winch dash controller. Installed a new temperature gauge. Replumbed the oil pressure line to gauge. Removed rear driveshaft to remake for a longer one.
I need to figure out how I am gonna hook up a brake switch, so I can have brake lights........I should have ordered the master cylinder that had the port for cruise control.
Old June 2nd, 2013, 04:37 PM   #929
s.hembree
s.hembree's Avatar
Just get an older style pressure switch. They're usually 1/8 npt so you can just get a brass "t" and put it inline.
Old June 2nd, 2013, 04:56 PM   #930
Or mount a normally open plunger switch on the brake pedal.
Old June 2nd, 2013, 05:03 PM   #931
jhnyquest
goof ball
jhnyquest's Avatar
This is what I did.
Old June 5th, 2013, 08:34 PM   #932
Replumned the buggy, while its the best brakes have been so far, its still not good enough.
Running the same size calipers, same master, same style of lines as the eb, only difference is booster and pedal. The pedal travels to far and I am not getting good stopping pressure. It does not feel like a power/manual brake booster issue. It feels like a bad master. Like the pressure is bleeding off and not holding. I have no leaks. Checked the rod in the booster for proper adjustment. I have bled it every which way.
Thinking of warranting the master and see what happens.
Old June 5th, 2013, 08:39 PM   #933
jbsjunk
Little Member
jbsjunk's Avatar
Can't remember what your pedal arrangement was, but I remember on some models, there was a power brake position for the rod and a manual brake position on the brake pedal. If those were opposite, it could make braking more difficult.
Old June 5th, 2013, 09:34 PM   #934
frdboy
frdboy's Avatar
Can you block off all the ports on the MC? If you do that and the pedal gets high and hard it is not a MC problem.
Old June 5th, 2013, 09:57 PM   #935
I tried that with the rear. Vice griped the nylon line just off the master before I replaced all the nylon lines and it made no difference in how it felt. Its loaded in the box truck so I can bring it to work and set up the alignment and I plan to dick with more in the a.m. probably gonna warranty the master out .
Old June 5th, 2013, 10:01 PM   #936
frdboy
frdboy's Avatar
Do you plug them off when you bench bleed it? That is how I normally do, plug off all the ports and pump it till piston movement is less than 1/8" Sometimes you have to tilt it in the vice to get all the trapped air out.
Old June 5th, 2013, 10:07 PM   #937
Clamp in vice, install brake lines to ports and bend the lines into brake fluid and submerge the ends. Slowly pump master pushing air out and pulling fluid back in when releasing piston. Repeat till no more air can be seen coming out of the lines.
Old June 5th, 2013, 10:22 PM   #938
frdboy
frdboy's Avatar
I used to do it that way as well, the nice part about blocking ports off is you know all the air is out when you can't move the piston much. If you are carefull removing lines you don't even have to bleed the brakes after a mc replacement. I would say 3 out of 5 I don't do anymore bleeding on the car after it is installed.
Old June 5th, 2013, 10:27 PM   #939
firehawk
Live Action!
firehawk's Avatar
Hydroboost brakes rock.
I have it on my 71 Bronco, a Mustang hydroboost tied into the Explorer pump.
Or is that too much along with full hydro steering?
Old June 5th, 2013, 10:36 PM   #940
The brakes on the EB were great. Never had an issue. That was with a 96 f250 master cylinder and booster. Now I have installed almost all of the same parts trying to get the same brake feel.
Page generated in 0.42469 seconds with 84 queries
