Mr. Beefy's "not quite yet U4 buggy" build - Page 43 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 24th, 2013, 08:16 PM   #841
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
I might need a driver but i am in...
Old May 24th, 2013, 08:36 PM   #842
Grassman
2jz specialist
Grassman's Avatar
im drunk
Old May 24th, 2013, 08:37 PM   #843
Grassman
2jz specialist
Grassman's Avatar
already, its free beer friday
Old May 24th, 2013, 08:39 PM   #844
GREASYHANDS
GREASYHANDS's Avatar
X2
Originally Posted by Grassman View Post
im drunk
Now lets see this brake set up. 4 ports or 2 it should still make pressure front or rear. If you looped two together that's your problem
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old May 24th, 2013, 08:42 PM   #845
Trail Junkie
iamfawkinwithyou
Dont you supply the beer for free beer fri?
Old May 24th, 2013, 08:45 PM   #846
Grassman
2jz specialist
Grassman's Avatar
yup, and it was high life this week. the champagne of beer curb would be proud
Old May 24th, 2013, 08:45 PM   #847
GREASYHANDS
Lol
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old May 24th, 2013, 09:08 PM   #848
dreezy
Haggard Fab
dreezy's Avatar
I'm bored, and if the wife was here, I'd be your driver.
Old May 24th, 2013, 09:32 PM   #849
bigblockford79
Big Block Ranger
bigblockford79's Avatar
It runs, but I can't get the brakes to bleed or work. Master cyl I purchased has four ports. Using two of them but I don't know the position of the ports vs front back .
What master cylinder do you have?
Old May 24th, 2013, 09:38 PM   #850
Grassman
2jz specialist
Grassman's Avatar
assist him sarah
Old May 24th, 2013, 09:39 PM   #851
GREASYHANDS
Check your push rod length
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old May 24th, 2013, 09:45 PM   #852
Shotgun
I only wheel with boats.
Shotgun's Avatar
Sarah, check his pushrod depth.
Old May 24th, 2013, 09:53 PM   #853
Grassman
2jz specialist
Grassman's Avatar
lol
Old May 24th, 2013, 10:23 PM   #854
bigblockford79
Big Block Ranger
Pedal bleeding or vacuum bleeding? If pedal bleeding, did you bench bleed the master?
If vacuum bleeding, make sure all connections are not sucking air. This has given myself and a couple others issues in the past. The vacuum will be lost at the bad seal point and may not have enough left to pull fluid out of the cylinder. If this is the case you might wake up tomorrow with a puddle somewhere after gravity has a bit more time to work its magic.
Port location shouldn't affect the ability to bleed the system but may change the overall performance if all 4 corners are pulling from the same piston travel section. Assuming you are using 1 forward and 1 rearward port and block the others you should be fine.
Old May 25th, 2013, 12:37 AM   #855
Pretty sure the master is bad. Push rod length fine, I think the master is bad and I may be leaking at some compression fittings. Bench bleeding doesn't seem to flow much fluid.
Old May 25th, 2013, 07:10 PM   #856
Managed to get brakes almost enough to work.
Old May 25th, 2013, 07:13 PM   #857
nd4spd71
nd4spd71's Avatar
Glad to see you got it going. How did the ex do hauling the buggy?
nd4spd71 is offline   Reply With Quote
Old May 25th, 2013, 07:22 PM   #858
Good except for stopping since I don't have a brake controller in it.
60 on surface roads, 65 on highway with cruise set. Averaged 11 mpg.
Old May 25th, 2013, 07:25 PM   #859
The wife laid into it pretty hard trying to earn her 1%er rating lol. The ori's are awesome to the least. I built my rear shaft to short at 2 am this morning so I had to use a ratchet strap to limit the rear travel. Still flexed awesome with it limited a lot.
But all in all being fresh out the box it ran and did very well.
Old May 25th, 2013, 08:09 PM   #860
xj4life
xj4life's Avatar
Pics!
Page generated in 0.42997 seconds with 84 queries
