CheapThrills "Fawk Yeah buggy" build - Page 42 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2013, 12:03 AM   #821
Bones
Bones's Avatar
Need more parts
And I can't figure out how to make my winters shifter work with my transmission. The driveshaft is to close and the cable is to dam stiff to bend and reroute.
get a longer cable. It's only money.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 22nd, 2013, 03:36 AM   #822
big86inthestixx
big86inthestixx's Avatar
Had this issue on a buddies c6 recently, I made a bracket so that the transmission shift bracket was pointed up, instead of down..and ran the shift cable looped from the bell housing and Pointed toward the t case..instead of looping toward the t case pointed at the engine.
Ill c if I can get pictures for ya.
This ended up bringing all if the, cable and shift bracket above the trans pan and reversed from the normal installation. Gave tons more clearance for his front driveshaft to the cable, and made the cable set in plac better. Lots less tighr turns.
Confusing as hell but hope thay helps a lil.
sended frum dis stoopid fone.
Old May 22nd, 2013, 05:47 AM   #823
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Have a similar setup on mine but for reasons I cant remember at the moment I wasn't able to invert the shift lever on the transmission. So I left the lever pointed down and switched the shifter body around which pushes the cable as you move from Park to 1st.
I used the tapped holes in side of the bellhousing where the factory shifter pivot/kickdown cable bracket used to be.
NOT sent from an iPhone
Old May 22nd, 2013, 07:35 AM   #824
The cable isn't long enough, to come from the bell housing to the shifter with the linkage pointed up. The cable would need to make an 'S' shape. And the cable that came with it is WAY to stiff to try and make the bends. The b and m cables could do it, but this one is much nicer and way more rigid then the cheap b and m's.
IF I could leave the winters shifter as it sits but make it push instead of pull that would be perfect. But I can't
Old May 22nd, 2013, 08:21 AM   #825
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Leave it for now shifting backwards, I have an idea....I'll build it for you.
Old May 22nd, 2013, 09:36 AM   #826
big86inthestixx
Here's the pic of what I did on my buddies jeep...realizing your cable isnt long enough, maybe this will help maybe not.
Old May 22nd, 2013, 03:46 PM   #827
Its more the cable is to stiff to bend like that.
Old May 22nd, 2013, 04:26 PM   #828
big86inthestixx
I had a cheap b and M cable you can have
:D
Old May 22nd, 2013, 04:35 PM   #829
big86inthestixx
*have
Old May 24th, 2013, 07:30 AM   #830
Need to fill fluids and hope for no leaks (all fluids).
Build a rear driveshaft yet but having trouble finding material to work with what I have.
Build my skid plate
mount pass seat and build shoulder strap tie downs
respool winch with my rope
I was really hoping to bring it to work today, even drove the box truck home last night with the off chance I might be able to. But couldn't.
While the winters/art carr is a nice unit, it sure is a motherfawking pain in the ass to deal with and set up. B and M is SO MUCH EASIER to deal with install.
Old May 24th, 2013, 12:06 PM   #831
Modified the muffler for clearance
Old May 24th, 2013, 02:48 PM   #832
jbsjunk
Little Member
jbsjunk's Avatar
Kind of like the section job Greg did with his. As long as it works, so what?
Old May 24th, 2013, 03:26 PM   #833
Thats where I got the idea
Old May 24th, 2013, 04:31 PM   #834
liv2mx
i like jungle gym's.
liv2mx's Avatar
Done yet?
Old May 24th, 2013, 04:39 PM   #835
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Talking
Beefy did his crossways...
It keeps your spare tire from burning up
Cheap Thrills Off Road
Old May 24th, 2013, 04:54 PM   #836
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Fo sho!
Lookin bad ass John!
Old May 24th, 2013, 08:36 PM   #837
It runs, but I can't get the brakes to bleed or work. Master cyl I purchased has four ports. Using two of them but I don't know the position of the ports vs front back .
Old May 24th, 2013, 09:05 PM   #838
GREASYHANDS
GREASYHANDS's Avatar
What did you do with the other two ports to block them? Pics?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old May 24th, 2013, 09:14 PM   #839
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
Say the word,.................I'll change clothes and head your way. I have the double fan out of the Flareside, and the one I was going to give Kyle M.
............Is it time for an old fashion CTOR Maylay?
FORD FLARESIDE is online now   Reply With Quote
Old May 24th, 2013, 09:15 PM   #840
nd4spd71
nd4spd71's Avatar
x2
nd4spd71 is offline   Reply With Quote
Page generated in 0.29742 seconds with 84 queries
