Mr. Beefy's "Fawk Yeah U4 buggy" build - Page 41 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2013, 09:39 PM   #801
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Originally Posted by BigBird View Post
Wish I knew this before the guys were here last weekend... Could have got you some 1/2 black uhmw on the cheap.... Might still be able to if you're not in a crazy hurry. Get me some rough dimensions and pm me.
If john needs it, get it to beefy and ill get it down here...
Old May 17th, 2013, 10:34 PM   #802
Ended up buying a torque converter today, wasnt planned, but after about 18 phone calls I couldn't find anybody that could clean a converter short of simply rebuilding it . Motor is loaded and hopefully gets set in tomorrow
Old May 17th, 2013, 10:52 PM   #803
GREASYHANDS
GREASYHANDS's Avatar
Pretty much got the front shaft sorted out..
Originally Posted by GREASYHANDS View Post
That seems like the simplest answaer right there. Or what about adapting a factory OEM style rear truck shaft, with a carrier bearing support?
I take all the credit for this
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old May 18th, 2013, 08:26 AM   #804
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Gotcha... Turns out there are a couple of others that are in the need for some uhmw as well. I'll see what can be done...
Cheap Thrills Off Road
Old May 18th, 2013, 03:03 PM   #805
Motor, trans, tcase installed and bolted down that was way easier then I thought . Well doing at the shop was way easier.
Old May 18th, 2013, 04:06 PM   #806
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Your old motor, new trans?
Old May 18th, 2013, 04:20 PM   #807
I think bones would get the most credit , since he actually ran it and used this style.
Yeah old motor and the trans I picked up from bones. Probably pick up another motor throughout the year and go through it with some mods and in the winter or so swap it out.
Old May 19th, 2013, 03:58 PM   #808
thrill20
thrill20's Avatar
I think I have some 1/2" uhmw also. Let me check tomorrow. More than likely a freebie.
thrill20 is offline   Reply With Quote
Old May 19th, 2013, 05:13 PM   #809
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I'd buy some from you too if you have lots.
Old May 19th, 2013, 05:44 PM   #810
I need about a 3'x3' atleast 3/8" thick. If anybody has some that would be sweet, sooner the better , Saturday is coming fast .
Running elec. sucks esc when shit doesn't match up .
Putting things together sucks when you realize you forget things, like welding in o2 sensor bungs on your exhaust, after your exhaust is installed .
Old May 19th, 2013, 10:04 PM   #811
Seems like everything I tried to do was met with complication after complication . Got some random shit done but not nearly as much as I needed to get done.
Old May 19th, 2013, 10:19 PM   #812
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Looks bad ass anyways
Old May 19th, 2013, 10:25 PM   #813
liv2mx
i like jungle gym's.
liv2mx's Avatar
get back to work on it..its early yet.u should be rocking 2 hours a sleep a night at the most this week.
Old May 19th, 2013, 10:28 PM   #814
I need more parts.
Old May 20th, 2013, 07:43 AM   #815
KennyOffroad
Ridge Runners Offroad
KennyOffroad's Avatar
Looks Good !
Old May 20th, 2013, 03:59 PM   #816
Last year I needed a hyd hose made for my power steering pump to orbital. The pump side had a specific fitting not found in hyd field. COmpany I was buying stuff from said they couldn't help me so I back yard hacked something together, while it worked for awhile it ended up failing and caught the eb on fire . So this time around I wanted it done better...all I needed was a fitting crimped or clamped onto a hose.
I went to mason dynamics---sent me to bond fluidaire cause they couldn't do anything
Bond Fluid aire sent me to thermo king because they couldn't do anything for me---
thermo king crimped the fitting to the hose for me, said no warranty if it leaked and charged me nothing . I am positive it won't leak and should serve me well .
Old May 20th, 2013, 05:46 PM   #817
Grassman
2jz specialist
Grassman's Avatar
what a runaround glad you got it sorted out
Old May 21st, 2013, 09:23 PM   #818
liv2mx
liv2mx's Avatar
Done yet?
Old May 21st, 2013, 10:03 PM   #819
KennyOffroad
Old May 21st, 2013, 11:17 PM   #820
Need more parts
And I can't figure out how to make my winters shifter work with my transmission. The driveshaft is to close and the cable is to dam stiff to bend and reroute.
Page generated in 2.75688 seconds with 84 queries
