Mr. Beefy's "not quite yet U4 buggy" build - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 19th, 2012, 05:59 PM   #61
Jeeper52
Budget, what budget?
Jeeper52's Avatar
What is the difference in feel between hydro assist and full hydro. Ive driven heavy equipment with full hydro and besides less feel, It seemed the same
Old November 19th, 2012, 06:00 PM   #62
trailrail302
Im going FAST!!!
trailrail302's Avatar
Nope, but it sounded great!
Section 257.710c
(4) Notwithstanding subsection (2), a person shall not operate a motor vehicle having lift blocks between the front axle and springs, or with lift blocks that exceed 4 inches in height between the rear axle and springs in addition to those provided by the original manufacturer. Any body lift block shall be of single piece construction and shall not use more than a 3-inch spacer. Any suspension lift block shall use an alignment pin between the axle and the spring, and shall be of single piece construction. Spring shackle replacements shall not exceed the original equipment manufacture length by more than 2 inches, and coil spring spacers are prohibited. All steering components shall be geometrically arranged to function as original equipment manufacture. Welded pitman arms, drag links, and tie rods are prohibited. All parts used to modify the original suspension or height of a motor vehicle shall be factory manufactured and shall meet or exceed the original manufacturer's specifications.
This thread is not about steering or whether or not it's to be a trailer queen.
No it's not but it is about John making good decisions for his build.
Full hydro is geometrically arranged to function as OE. It adjusts both tires together as the steering wheel is rotated. Since there is no pitman arm, drag link or tie rod, that portion does not apply.
To me, it's still grey enough that it could be argued. Won? I hope I don't have to try.
Either way, after having no assist, hydro assist and full hydro, for a buggy I would not even consider anything but full hydro.
not to mention that this all says this special verbage "to manufactures specs" if its an assembled vehicle and it is assembled with hydro steering than that is the manufactured set up. also the above section seems to be more directed to modifications such as lift kits etc...not manufactured items which they would be if you title it as assembled. It can and has been done.
trailrail302 is offline   Reply With Quote
Old November 19th, 2012, 06:47 PM   #63
I haven't noticed any feel off road in the way of reaction but my assist did pretty good. Definitely turns smoother in binding situations.
On highway it wanders a little more. That and the internal leakage of the orbital lets the wheel gradually drift. I've driven 30+ miles to a trail head and didn't feel uncomfortable.
Old November 19th, 2012, 07:39 PM   #64
Are your links holding your heims on your full welded whiterhino? John was running a single ended ram with a tie rod. Not sure if he had welded in bungs on the tie rod or not but I think he does. My tie rod and drag link have welded joints so i'm in violation as well. If he's going to have a bronco vin, it won't be manufacturers spec.....but again, why the f does it matter? I'll go out on a limb and say he's not going to sacrifice offroad performance for on road legality. Back to the bronc....err buggy build
Old November 19th, 2012, 07:50 PM   #65
Hiems at the knuckles with weld in bungs and a single ended ram is what I was running on the bronco the last few months, prior was heims at knuckles, weld in bungs, but a tie rod at the pitman and no assit.
Will it be driven on the road-yes, will I drive it on the road for any other reason to get directly from point a to b to wheel-no
Old November 19th, 2012, 07:55 PM   #66
Fuel cells.......
I have zero desire to run a external pump, my old tank was 19 gallons and was just about perfect for fuel usage with my combo. My pump was 40 gph and 45psi operating pressure. Are there options out there for good fuel cells and running an in tank pump? I prior setup was a 96 f250 rear tank, stock sender and pump etc...if I could I would just rerun the same tank but I can't.
Old November 19th, 2012, 08:13 PM   #67
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Why not modify a cell, like the one I have for an intank pump? That is if you can't reasonably buy one.... I bet we could make it work, do mine st the same time. I have a stock ranger unit I was gonna mod to put in my cell one of these days.
Old November 19th, 2012, 08:56 PM   #68
pinktaco
Better than i deserve
pinktaco's Avatar
Originally Posted by liv2mx View Post
john at least do aluminum links for your lowers. my lowers are bent after less then a year wheeling. dom just does not hold up to hard hit's,all the southern guys run aluminum and a lot of the koh cars are also.im switching to aluminum. i have 1 1/4 heims also.
On my buggy we took 1/4 wall 2 inch DOM and pounded torsion bars from a toyota pickup into them this setup will not bend or break but is heavy as shit. They also basically the same cost as the DOM if you can source the torsion bars for cheap
pinktaco is offline   Reply With Quote
Old November 19th, 2012, 08:57 PM   #69
chevotass
chevotass's Avatar
modify a cell or pay the baller type money for the aftermarket stuff. im in the middle of this process now. i have the pump mounted in tank. now i have to find a way of getting the power wires out of the cell safely.
Old November 20th, 2012, 05:12 PM   #70
Got some indirect work done on it today. Split from work early and spent a couple hrs power washing my axles and rims/tires. Suppose to get my truss's and my coilover mounts tomorrow. Waiting on another shipment from ruff stuff and my clocking ring.
Still in need of a 80's kingpin 60 or another bj 60 housing.
Old November 20th, 2012, 05:57 PM   #71
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Didn't rocksolid get you a quote on retubing it?
Old November 20th, 2012, 07:13 PM   #72
Just ordered my seats....
Corbeau Ultra SS vinyl/clothe
http://broncograveyard.com/bronco/i-...ed-center.html
Old November 20th, 2012, 07:30 PM   #73
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Can you pick them up to save shipping? That seems like a great price....I'm gonna have to put my ass in em...
Old November 20th, 2012, 07:34 PM   #74
Them and wildhorse4x4 were the cheapest I could find. I don't think they are getting shipped from JBG, I imagine they are getting dropped shipped.
Old November 20th, 2012, 07:35 PM   #75
firehawk
Live Action!
firehawk's Avatar
Fuel cells.......
I was going to weld an explorer setup into my 71 Bronco tank, not the stock one I have a bigger aftermarket one. 23 gallon I think.
I have the whole tank with pump and was going to cut the section out of the stock tank and weld to the bronco tank.
Not sure if I will ever get to it but could work for you or use any tank you wish.
Old November 20th, 2012, 07:40 PM   #76
I don't think a modified tank of that sort would pass tech, I kinda would like to potentially enter trec once or twice if I got a wild hair to race.
Old November 20th, 2012, 08:42 PM   #77
deathbypsi
Brian R.
deathbypsi's Avatar
http://www.jegs.com/p/Aeromotive/Aer...32859/10002/-1
a bit spendy but the only option I have ever found.
Old November 20th, 2012, 09:31 PM   #78
liv2mx
i like jungle gym's.
liv2mx's Avatar
done yet? i did mine from scratch in 3.5 months. the way you work,you should easily have this done by snofari.
Old November 20th, 2012, 09:46 PM   #79
If they are coming from JBG I can pick them up for you. I work a mile away. Then I could get them to Josh.
Old November 21st, 2012, 09:09 AM   #80
Get married, have a kid, and a 60 hr a week job. I know when you were doing yours you werent working a full time job the wjole time
Page generated in 0.60334 seconds with 84 queries
