Mr. Beefy's "Fawk Yeah U4 buggy" build - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 17th, 2012, 03:31 PM   #41
jhnyquest
goof ball
jhnyquest's Avatar
So when's the shake down run?
Old November 17th, 2012, 03:36 PM   #42
tonka toy
It's got a HEMI!
tonka toy's Avatar
http://www.liftlaws.com/is_full_hydr...reet_legal.htm
Considering these laws, it is quite possible to design and build a safe full hydraulic steering systems that meets the requirements of all states with the exception of Tennessee. Although these laws don't specifically prohibit full hydraulic steering, that does not necessarily make it legal. That in mind, the risks of running a full hydraulic steering setup are mainly fix-it tickets and lawsuits.
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old November 17th, 2012, 03:42 PM   #43
Tacker
Tacker's Avatar
I heard Snofari....
Old November 17th, 2012, 03:47 PM   #44
jhnyquest
goof ball
jhnyquest's Avatar
Lol
Old November 17th, 2012, 04:00 PM   #45
Tacker
Tacker's Avatar
Old November 17th, 2012, 05:49 PM   #46
cerial
Direct Drive FTW
cerial's Avatar
Nissan is going to have a full drive by wire system in there 2013 models.
Maybe the full hydro thing might loosen up a bit with a brand sold nationally that has passed DOT standards driving next to you on the highway at 90 mph without any steering shaft.
I think if you get a officer butt hurt over anything it will be the bracing in the windshield causing a obstructed view.
Great build
Thanks for showing the carrier and including a link.
Old November 17th, 2012, 06:41 PM   #47
Just to clarify the extent of driving on roads would be to/from trail heads, campgrounds to parks etc....not gonna be driving this to work or to get groceries etc...
Old November 18th, 2012, 07:03 AM   #48
So question time.....plan is to use 1.25 hiems on the links, what is the ideal material for the links themselves.....think liv2mx style wheeling .
Also with the front driveshaft...carrier style set-up in front of the tcase. Was looking at PJ's setup..http://mandmfab.com/id14.html
Thoughts?
I have the standard bronze spherical bearing and like Nick said, it needs to be replaced occasionally but I don't think every year. I make sure I grease it all the time to keep it from getting sloppy. If I had it to do over again I would look at something like that or a factory style like Bones has. The biggest time it sees wear is highway driving with drive flanges where it is spinning fast for extended times. Normal trailer queen stuff like we do doesn't seem to bother it much.
I assume you are going to have a telescoping shaft between the t-case and carrier bearing?
I have 1.75 x 1/4 wall lower links and I have to pull and straighten them every year. All links have Ballistic joints and I hate them. I blew one out this weekend in Canada and ran all day yesterday with it clunking like crazy. I'm going to 2" Aluminum but haven't decided on which joint to use. I need to talk to Dale about the brands he carries.
Old November 18th, 2012, 08:31 AM   #49
Jeeper52
Budget, what budget?
Jeeper52's Avatar
I agree why would you drive your expensive tires on the highway anyway. I would drive at city speeds where you have more reaction time. Not for legality but for safety.
Old November 18th, 2012, 08:33 AM   #50
bluminade
Bluminade Has Arrived
bluminade's Avatar
Originally Posted by GearDrive View Post
Where do you guys buy the 7075 aluminun? I need to replace my bent links too.
you can get them at RSP (rock solid performance)
they can custom build them for whatever you want.
bluminade is offline   Reply With Quote
Old November 19th, 2012, 09:27 AM   #51
Drivetrain in yet?
Old November 19th, 2012, 09:31 AM   #52
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
He's probably driving it by now.
Old November 19th, 2012, 09:50 AM   #53
Haven't touched it yet. Waiting on parts, and waiting on the oppurtunity to work on it for then 30 minutes at a time. And I probably won't get that till weds evening if I am lucky.
Old November 19th, 2012, 11:07 AM   #54
GearDrive
A little slow
GearDrive's Avatar
Yes, I did talk to them, and figured I could save some coin by machining them myself.
CheapThrillB2: If you decide to use the aluminum links, I might be able to make some for you when I do mine. I work in GR and have some property in Middleville.
GearDrive is offline   Reply With Quote
Old November 19th, 2012, 11:35 AM   #55
Good to know, keep it in mind when the time comes.
Picked up some fenders and grille yesterday as well as a pair of 5 point harness's.
My first order from ruffstuff showed today, now I can start on motor and trans mounts-crossmembers.
Old November 19th, 2012, 11:36 AM   #56
Old November 19th, 2012, 01:27 PM   #57
Tab
Tab's Avatar
Why the fukc does it matter? With full hydro steering it isn't legal anyways.
Really? You sure about that?
Old November 19th, 2012, 01:43 PM   #58
Nope, but it sounded great!
Section 257.710c
(4) Notwithstanding subsection (2), a person shall not operate a motor vehicle having lift blocks between the front axle and springs, or with lift blocks that exceed 4 inches in height between the rear axle and springs in addition to those provided by the original manufacturer. Any body lift block shall be of single piece construction and shall not use more than a 3-inch spacer. Any suspension lift block shall use an alignment pin between the axle and the spring, and shall be of single piece construction. Spring shackle replacements shall not exceed the original equipment manufacture length by more than 2 inches, and coil spring spacers are prohibited. All steering components shall be geometrically arranged to function as original equipment manufacture. Welded pitman arms, drag links, and tie rods are prohibited. All parts used to modify the original suspension or height of a motor vehicle shall be factory manufactured and shall meet or exceed the original manufacturer's specifications.
This thread is not about steering or whether or not it's to be a trailer queen.
Old November 19th, 2012, 05:15 PM   #59
Tab
Tab's Avatar
I was asking for real. I always thought it was a grey area since some vehicles come with hydro steering and/or hydro assist. FWIW my full hydro works and feels better than it did with the old sloppy stock stuff.
Old November 19th, 2012, 05:53 PM   #60
No it's not but it is about John making good decisions for his build.
Full hydro is geometrically arranged to function as OE. It adjusts both tires together as the steering wheel is rotated. Since there is no pitman arm, drag link or tie rod, that portion does not apply.
To me, it's still grey enough that it could be argued. Won? I hope I don't have to try.
Either way, after having no assist, hydro assist and full hydro, for a buggy I would not even consider anything but full hydro.
Page generated in 0.49366 seconds with 84 queries
