Mr. Beefy's "not quite yet U4 buggy" build - Page 22 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2013, 06:38 PM   #421
chevotass
chevotass's Avatar
is it done yet?
Old January 5th, 2013, 07:19 AM   #422
Time to start the front tear done and rebuild. So whats the best route with kingpins....springless caps? Anything better out there as far as rebuild kits etc? First time dealing with kingpins. Always had ball joint 60s before this.
Old January 5th, 2013, 07:19 AM   #423
I also ordered some new suspension components
Old January 5th, 2013, 07:24 AM   #424
jhnyquest
goof ball
jhnyquest's Avatar
I run springless.
Old January 5th, 2013, 07:26 AM   #425
Cool parts peddler
Ironman Offroad's Avatar
Spring less here also..
Old January 5th, 2013, 07:35 AM   #426
Mine are stock. I've been running them since 2008 without issue.
Old January 5th, 2013, 07:59 AM   #427
Hott!
Old January 5th, 2013, 08:01 AM   #428
Tacker
Tacker's Avatar
I have springless caps too. Are you going to run high steer arms John?
Old January 5th, 2013, 08:04 AM   #429
Grassman
2jz specialist
Grassman's Avatar
I run standard high steer with springs..what is the advantage of springless?
Old January 5th, 2013, 08:06 AM   #430
bluminade
Bluminade Has Arrived
bluminade's Avatar
mine are spring less also. using the spring style off road will wear out the plastic cones quicker.
pull it apart first and see what it needs before ordering the hole kit, most only need the plastic cones.
bluminade is offline   Reply With Quote
Old January 5th, 2013, 08:12 AM   #431
Grassman
2jz specialist
Grassman's Avatar
I've seen the springless come loose, wouldn't standard stay in adjustment with the spring?
Old January 5th, 2013, 08:14 AM   #432
I have standard springs because I don't run highsteer.
Old January 5th, 2013, 08:16 AM   #433
jhnyquest
goof ball
jhnyquest's Avatar
I've seen lugnuts come loose on alum wheels too.
Old January 5th, 2013, 08:19 AM   #434
Shit I better get rid of mine!
Old January 5th, 2013, 08:20 AM   #435
jhnyquest
goof ball
jhnyquest's Avatar
Good idea
Old January 5th, 2013, 08:22 AM   #436
Grassman
2jz specialist
Grassman's Avatar
Price please? I'll take the tires too
Old January 5th, 2013, 10:52 AM   #437
Undecided in high steer till truss is on and start playing with hyd. Ram
Old January 5th, 2013, 12:15 PM   #438
Getting there.
Old January 5th, 2013, 12:16 PM   #439
jhnyquest
goof ball
jhnyquest's Avatar
Slow at work today?
Old January 5th, 2013, 12:52 PM   #440
Most def.
Page generated in 0.27077 seconds with 84 queries
