Mr. Beefy's "not quite yet U4 buggy" build - Page 19 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 25th, 2012, 05:03 PM   #361
liv2mx
i like jungle gym's.
liv2mx's Avatar
make sure the distance from your left upper and right lower is the same from front to back.does not look like it is.
Old December 25th, 2012, 05:08 PM   #362
Bones
Bones's Avatar
do you mean upper and lower link seperation? I always like to have difference in the seperation, ususally I aim for 8-9" seperation on the axle and 6-7" seperation on the chassis.
edit- as far as triangulation in the links, I aim for atleast 30deg of triangulation. So for example, if your lowers are straight and parallel to each other, the uppers need to have 30deg triangulation in relation to the lowers. Or, your lowers can have a 10 deg difference to easch other (10 degrees non-parallel), then your uppers canhave a 20 deg difference to each other (combines for 30 deg).
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 25th, 2012, 05:11 PM   #363
Originally Posted by Grassman View Post
Don't feel bad, I haven't a clue what that stuff means. Tutorial Brandon?
I just got off the phone with trying to edumicate me
Old December 25th, 2012, 05:13 PM   #364
Grassman
2jz specialist
Grassman's Avatar
Do you feel smarter?
Old December 25th, 2012, 05:15 PM   #365
A bit better understanding, yes.
Old December 25th, 2012, 05:25 PM   #366
Old December 25th, 2012, 05:28 PM   #367
liv2mx
liv2mx's Avatar
not talking seperation, but yea 5 to 7 on frame 8 to 10 on axle for seperation.
it's hard to explain.but if you stand at the back and look at the left upper bar and right lower bar.they need to be as close as you can get them to the same distance from the front mounts on the frame to the rear mounts on the axle.so your rear 4 link bars will be like 2 box's. this is very important.
from the picture it looks like your upper axle mounts on the truss,could come in closer.
Old December 25th, 2012, 05:30 PM   #368
liv2mx
liv2mx's Avatar
i showed brandon at the badlands what i mean.
Old December 25th, 2012, 05:54 PM   #369
I need to bite the bullet and buy excel
Old December 25th, 2012, 06:13 PM   #370
Triangulation in the uppers and lowers as layed out. Again, I'm just doing the numbers, I'm no expert.
9.6 x 2=19.2 deg in the uppers, 8.4 x 2 = 16.8 deg in the lowers. So 36 deg of triangulation.
Erin, I layed mine out like you talked about and my roll steer got worse. On Johns above it's 24 at the frame and 25 at the axle so they're within an inch of "parallel" The roll axis goes from -.9 to -.5 if I bring the lower axle side in to 17 and make it 24 and 24 but the triangulation goes from 36deg down to 33 deg. Bones default was min 30 so they both qualify, I'm not sure what effect it would have with the lowers at 36" separation at the axle vs 34".
Old December 25th, 2012, 06:24 PM   #371
I found an product key that works
Old December 25th, 2012, 06:28 PM   #372
I think there's a web based version that still works in the link on pirate so you wouldn't have to buy excel.
Old December 25th, 2012, 06:30 PM   #373
Nice
Old December 25th, 2012, 06:50 PM   #374
I should be able to look at it in person in a few days hopefully.
Old December 25th, 2012, 06:53 PM   #375
Grassman
2jz specialist
Grassman's Avatar
I want to meet you there, hopefully I can learn a thing or 2...
Old December 25th, 2012, 06:55 PM   #376
I don't know much more than the thread I read and a couple conversations with 95geo about doing mine. I'm just the guy putting stuff into excel. Hopefully more people will chime in and we can all learn something about it.
Old December 25th, 2012, 06:57 PM   #377
Grassman
2jz specialist
Grassman's Avatar
You could show us what all that paper shit is in real world application
Old December 25th, 2012, 07:02 PM   #378
s.hembree
s.hembree's Avatar
He's an enginerd, they're clueless when it comes to real world application... they only know paper shit.
Old December 25th, 2012, 07:03 PM   #379
I think the biggest difference is that you read it and comprehend and understand. In all honestly I don't learn shit from reading, I learn from hands on.
Old December 25th, 2012, 07:04 PM   #380
These are the boxes Erin is talking about. It can get a little weird because you're dealing with 3d locations for roll steer as well as the 2d "boxes" that Erin's talking about.
Page generated in 0.37674 seconds with 84 queries
