Mr. Beefy's "Fawk Yeah U4 buggy" build - Page 14 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 5th, 2012, 08:37 PM   #261
jhnyquest
goof ball
jhnyquest's Avatar
Very well. Looks good. Carry on.
Old December 5th, 2012, 08:55 PM   #262
crosseyed cat
safety cone killer !!!
crosseyed cat's Avatar
lookin good . might have 2000 style ford D-50/60 keep up the good work
crosseyed cat is offline   Reply With Quote
Old December 5th, 2012, 09:02 PM   #263
I have an axle, just not in my possession, its currently out getting a new pass tube. Pretty sure I broke it jumping logs during the sand lake obstical course
Old December 5th, 2012, 10:05 PM   #264
firehawk
Live Action!
firehawk's Avatar
Tcase clocked
Where did you get the clocking ring?
I wanted to clock mine up but the floor is in the way and I am not cutting it.
Old December 5th, 2012, 10:06 PM   #265
Northwest fab
http://www.northwestfab.com/NP205-Ro...Down_p_14.html
Old December 5th, 2012, 10:22 PM   #266
firehawk
Live Action!
firehawk's Avatar
What are you using for the 205 shifter(s)?
I want to run cables and levers but have the stock handle on it now.
Old December 6th, 2012, 12:00 AM   #267
cerial
Direct Drive FTW
cerial's Avatar
That was alot of welding lol.
That's so freaking clean.
Old December 6th, 2012, 06:41 AM   #268
HAven't addressed that yet.
Old December 6th, 2012, 06:43 AM   #269
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Nice work on that truss John
Everytime I seen Chuck's I wanted to hump it.
You've been warned
Old December 6th, 2012, 06:45 AM   #270
I really like artec's stuff.
Right now I will be running both truss's, lower coil over mounts, fuel cell mount, all but the front lower link mounts at chassis are artec's stuff.
Old December 6th, 2012, 07:41 AM   #271
Trans Crossmember done. Well part of it, gonna tie the tcase into it as well for support of that heavy pig.
Bushing by the case as well? I was warned about having bushings way out like that about cracking transmissions and I think I cracked the tail housing at MI. Won't know til I pull my skid off but I has lots of fluids that I didn't has prior to Mission Impossible.
Old December 6th, 2012, 07:46 AM   #272
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
are you talking about the bushings at the ends of the cross member itself? My flareside crossmember looks just like John's. I hope I didn't screw something up!
Old December 6th, 2012, 07:52 AM   #273
Mine is done the same way, think about the amount of torque needed to move a bushing out there vs right next to it. It's not recommended to do them that way.
Old December 6th, 2012, 07:54 AM   #274
FORD FLARESIDE
So, solid mount to the frame and bushing right at the case is what I need to do? I would have never thought of that on my own.
Old December 6th, 2012, 08:01 AM   #275
Just a rubber/poly bushing close to the Trans/T-case to allow some give. I wouldn't solid mount it to the frame but I guess it really wouldn't matter. My poly mounts at the frame don't move and that's not good since I don't have any thing closer to the trans that does move.
Old December 6th, 2012, 08:02 AM   #276
trailrail302
Im going FAST!!!
trailrail302's Avatar
Baller!!!..
trailrail302 is offline   Reply With Quote
Old December 6th, 2012, 08:21 AM   #277
FORD FLARESIDE
I've got some refabbin' to do.
Old December 6th, 2012, 08:50 AM   #278
firehawk
Live Action!
firehawk's Avatar
I have one mounted off the factory location on my Bronco and welded to the frame, I used a poly bushing inside of tube. Will this be an issue? I have factory motor mounts and trans mount.
Old December 6th, 2012, 08:56 AM   #279
http://www.greatlakes4x4.com/showthr...highlight=d300
Sorry for the Hi-jack, back to buggy build.
Old December 7th, 2012, 12:02 PM   #280
Considering in the eb the trans tcase factory mount i was using tore at one point so I chained the trans and tcase down to the crossmember and chained it left and right to the frame with turn buckles to tighten .
Page generated in 0.52968 seconds with 84 queries
