Road walking - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2012, 03:18 PM   #1
Theredneck71
Default Road walking
I just bought a 86 ford bronco with a 6in lift and 35in super swamper boggers and it road walks so bad you can't go over 30 mph. Is there anything I can do to stop this or do I need just buy some all terrains to put on it?
Theredneck71 is offline   Reply With Quote
Old November 12th, 2012, 03:32 PM   #2
hondadirtracer
Skymaster
hondadirtracer's Avatar
If it is that bad then it is more than likely not your tires, but instead something in your steering components.
hondadirtracer is offline   Reply With Quote
Old November 12th, 2012, 03:35 PM   #3
in2deep
Hole tester
what is this road walking you speak of, is it walking or more of a jog, full out run?
Old November 12th, 2012, 03:48 PM   #4
XXXJ
Desert Rat
XXXJ's Avatar
Walk on the left, facing traffic
Old November 12th, 2012, 09:06 PM   #5
Elvis13
I'm guessing one tire is not pointed in the same direction as the others.
Old November 12th, 2012, 10:47 PM   #6
gear_grinder
"road walking" is not a term used to describe handling
i generally walk on sidewalks where i have a chance to jump out of the way should someone karreen out of control with a shotty 4x4
if the vehicle death wobbles, pulls, shimmies, or leads, that is a more definable term leading to more accurate diagnosis
gear_grinder is offline   Reply With Quote
Page generated in 0.26595 seconds with 41 queries
