if tj had abs on dana30, does new axle need it? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2012, 10:55 AM   #1
gattaca37
gattaca37's Avatar
Default if tj had abs on dana30, does new axle need it?
Have a 97 tj with a Dana30 with abs, lookn to swap in a 96-99 xj Cherokee HP Dana30. Does the HP have to be abs equipped?
Do I even need the abs Shit on the tj? It's on road and off road jeepin that she does, not a dd
gattaca37 is offline   Reply With Quote
Old November 12th, 2012, 10:57 AM   #2
Toyfish
Toyfish's Avatar
It will be fine without the abs but it will have a abs light constantly on in the dash if u can live with seeing the light then dont bother with the abs. i personally dont like abs anyways
Old November 12th, 2012, 11:12 AM   #3
Zach4739
2005 Willys
Zach4739's Avatar
abs is terrible when your wheelin id just pull the fuse/relay for it and live with the light bein on
Zach4739 is offline   Reply With Quote
Old November 12th, 2012, 11:13 AM   #4
cerial
1200PSIg Double acting
cerial's Avatar
My 01 tj never had abs and it was a dd. Part of the reason I bought it.
You can always pull the instrument cluster and snag the bulb. Or go all old school with some electrical tape.
You need abs about as much as you need a front sway bar. Just respect that it is not a sports car and you will be fine.
Old November 12th, 2012, 11:17 AM   #5
Toyfish
Toyfish's Avatar
Nope u cant pull the bulb in these i tried to with my check enging light on my 01 tj its all built into the cluster the only bulbs that r changable r the one that light up the gauges
Old November 12th, 2012, 12:43 PM   #6
Dylan
Dylan's Avatar
you can unbolt the sensors at the wheels and just tie them up under hood. You will also need to unhook the rear sensor and tie them up also. Just leave them plugged in.
Old November 12th, 2012, 01:58 PM   #7
gattaca37
gattaca37's Avatar
Thanks
Old November 12th, 2012, 02:05 PM   #8
kickstand
circling the drain
kickstand's Avatar
you don't need to do anything special. But your abs light will be lit. that is all.
Old November 12th, 2012, 03:07 PM   #9
ajmorell
ajmorell's Avatar
If you want to keep ABS, and the hp30 axle was a non-ABS axle, swap over your LP30 knuckles and you'll be good to go.
Old November 13th, 2012, 01:23 AM   #10
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
For the light
http://www.zr2usa.com/mboard/index.php?showtopic=40878
Same concept anyway
Page generated in 0.19190 seconds with 53 queries
