Military Dump Trailer M101a2 -----SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 12th, 2012, 05:10 AM   #1
656owner
656owner's Avatar
Default Military Dump Trailer M101a2 -----SOLD
M101A2 3/4 ton trailer. 5x8 box, surge brakes, pintle hitch.
Unable to load photo's,
$800.
656owner is offline
Old November 12th, 2012, 08:36 AM   #2
Chief Brody
Get off my lawn.
Chief Brody's Avatar
Chief Brody is offline
Old February 10th, 2013, 07:27 AM   #3
alterego
alterego's Avatar
Will you measure the widest point across this trailer and post up or PM me the widest distance? I want to know ifI could back it into my basement door opening 5' 10" wide.
alterego is offline
Old February 23rd, 2013, 04:52 PM   #4
656owner
656owner's Avatar
The widest point measures 6FT 1.5 INCHES.
These trailers use standard GM 8 lug rims.
656owner is offline
Old March 4th, 2013, 07:04 PM   #5
656owner
656owner's Avatar
Length, overall 147 inches
Length, cargo box 76 inches
Width, overall 73.5 inches
Width, cargo box 65.5 inches
Height 35 inches
Height w/cover 83 inches
Ground clearance 14 inches
Weight 1,340 lbs
Capacity 1,500 lbs (M101A3: 2,000 lbs)
Note: Dimenstions are for the M101A2 variant.
656owner is offline
Old February 6th, 2014, 08:19 PM   #6
656owner
656owner's Avatar
Repainted the trailer.
M101A2.
3/4 trailer, surge brakes, park hand brakes, pintle hitch, and has side racks 16.5 8 lug rims.
$750. or best offer.
656owner is offline
Old February 6th, 2014, 09:37 PM   #7
techman
How does the trailer dump? How much of an angle?
techman is offline
Old February 7th, 2014, 05:14 AM   #8
656owner
656owner's Avatar
There are 2 bolts that hold the box to the tongue, these are removed, pull the hand brake levers and last put the tow vechicle in reverse. Which causes the trailer to hinge at the tongue, raising the bed in about a 45 degree angle.
I am told there is a you-tube video of this.
656owner is offline
Old February 7th, 2014, 05:48 PM   #9
techman
Interesting... Off to you-tube
-tim
techman is offline
Old February 9th, 2014, 08:48 AM   #10
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
FYI - these trailers are not designed to dump (I owned an M101A3). Pivot angle is wrong, and it'll stress the brackets. It was designed for transport only.
Nice trailer, BTW.
1x1_Speed_Craig is offline
Old February 12th, 2014, 11:08 AM   #11
656owner
656owner's Avatar
Although the you tube video shows that it does dump. It was not designed to dump. It was designed to be able to remove the tongue during shipping.
The M101A2 is composed of an M101A2 cargo box mounted on the M116A2 Chassis, Trailer, 3/4 Ton 2 Wheel and the M101A3 is similarly built upon the M116A3 chassis.
M-101 Trailer, Cargo, 3/4 ton Specifications
Length, cargo box 100 inches
Height, overall, empty, with cover 83 inches
Height, cargo box 19.64 inches
Fording depth 30 inches
Weight, empty 1,340 lbs
Payload, cross country 1,500 lbs
Payload, highway 2,250 lbs
656owner is offline
Page generated in 0.28330 seconds with 56 queries
