cherokee hp dana30 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 11th, 2012, 04:08 PM   #1
gattaca37
gattaca37's Avatar
Default cherokee hp dana30
Have a 97 tj with lp Dana30 and upgrading to an xj HP Dana30. I have found a 94' HP Dana30 but have read the best r the 96-99 due to the 760x u joints. The 94 happens to have the same as my lp Dana30 in wrangler. Is this the only difference, the u joints? I can change those out to the larger 760x right?
Dude is asking $150 for the 94 xj HP Dana30
Tell me what u think? The reason for swap is because pinion nut backed off and gerenaded the r&p on lp Dana30 tj. Have to gear either one back to 4.56 and felt the HP runin on drive side is stronger in r&p so might aswell spend $150 for a better axle
gattaca37 is offline   Reply With Quote
Old November 11th, 2012, 09:39 PM   #2
Wramblerguy
Wramblerguy's Avatar
your tj should have the larger size u-joints and you can just put your tj shafts in the hp housing
3rd generation jeeper
Old November 11th, 2012, 10:30 PM   #3
ajmorell
$150 for a complete hub to hub axle? If not pass. I paid $20 for my hp30 less shafts and brakes
Sent from my DROID BIONIC using Tapatalk 2
Old November 12th, 2012, 01:01 PM   #4
gattaca37
gattaca37's Avatar
What r u sayn the price should be on the 96-99 xj HP Dana 30 then?
Old November 12th, 2012, 02:06 PM   #5
ajmorell
I wouldn't pay more than $100 for one, unless it was complete including the shafts, knuckles and brakes. I'd pay more if it'd been regeared, locked, etc...
Old November 12th, 2012, 05:06 PM   #6
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
I payed 150 for one complete. They are in high demand right now.
tcxtreme1000 is offline   Reply With Quote
Old November 12th, 2012, 06:15 PM   #7
gattaca37
gattaca37's Avatar
R the u joint in tj axle shaft Dana30 weaker or the same as the u joints in the 96-99 xj HP Dana30? I read the xj has 760x which r the same as the Dana44 in wranglers. R the axle shafts the same strength?
Old November 12th, 2012, 07:16 PM   #8
Wramblerguy
Some 95 wrangler and all 96 and up jeeps have 760 sized joints
You can check with a quarter
The 760 u-joint cap is bigger then a quarter and the smaller one is about the same size
Old November 12th, 2012, 08:04 PM   #9
gattaca37
gattaca37's Avatar
That will help. I've done some research and have found that the abs xj HP Dana30 had the 760x u joints. The non abs ran 297x.
So I am in the market for an abs 96-99 xj HP Dana30 if u or know of anyone who has one please pm me.
Old November 12th, 2012, 08:07 PM   #10
Wramblerguy
i am 90% sure that the 760 is just an updated cold forged, stronger but the same size u joint as the 297
Old November 12th, 2012, 08:08 PM   #11
Wramblerguy
http://.activeboard.com/t15034071/sp...760x-u-joints/
Old December 8th, 2012, 07:23 PM   #12
rda616
rda616's Avatar
Yep!
rda616 is offline   Reply With Quote
Old December 8th, 2012, 07:29 PM   #13
rda616
rda616's Avatar
The 5-760x is a replacement for the 297x. The smaller joint is the 260x found in pre 96 non abs models. I played $ 50.00 for my hp30. If you can find a 4 cylinder 5 speed Cherokee it will have 4.10 gear as well.
Old December 8th, 2012, 08:19 PM   #14
yyj87
yyj87's Avatar
I have sold 3 in thee last year for $100 or so. All without axle shafts/bearings.
Buy a $400 Cherokee, remove front axle, trans and t case.
Scrap everything else!
Sell trans $100
Sell t case $100
Scrap $350
hpd30 project will cost you -$150 or keep a pile of spare parts around
Parting beaters is a spectacular way to get cheep parts!
yyj87 is offline   Reply With Quote
Old December 8th, 2012, 08:25 PM   #15
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
I have a 94 XJ HpD30 with 97 TJ shafts and 5-760 spicer joints under my 5.9 ZJ.
No problems locked on 33's
Page generated in 0.29782 seconds with 68 queries
