BBC parts, HT starter, cam, carb, etc - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 8th, 2012, 04:13 PM   #1
moparhorse
moparhorse's Avatar
Default BBC parts, HT starter, cam, carb, etc
-Solid lifter cam from Comp with lifters #11-324-4 814 $100 Only broke in and then has a few dyno pulls on it
-Mallory distributor $45
-Steel valve covers and timing cover $35
-Balancer for steel crank $25
-High torque starter from powermaster $75
-Holley 850 double pumper that was done by barry grant. $650
Brandon 989-513-4827
moparhorse is offline   Reply With Quote
Old November 30th, 2012, 09:31 PM   #2
clean85k20
interested in any trades?
clean85k20 is offline   Reply With Quote
Old December 1st, 2012, 08:15 PM   #3
clean85k20
pm sent
Old December 2nd, 2012, 08:10 AM   #4
Suta99
Suta99's Avatar
You have dyno sheets? What kind of cam does it have and did this run on pump gas?
Old December 2nd, 2012, 02:11 PM   #5
moparhorse
moparhorse's Avatar
No dyno sheet. Main reason for putting it on the dyno was just to break it in. Its a comp solid lifter cam. Not to sure on the numbers. It ran on 110 octane
Old December 9th, 2012, 10:32 AM   #6
Suta99
Suta99's Avatar
This was for a boat? Nobody runs race fuel in a boat for only 600 hp
Old December 9th, 2012, 01:33 PM   #7
moparhorse
moparhorse's Avatar
It was dident make enough power, thats why it never went into the boat. The boat needs 650hp to utilize the pump. Maybe if you have the money to blow like I do then it wouldent matter, and I live on a lake
Old December 16th, 2012, 08:11 PM   #8
Suta99
Suta99's Avatar
Who blows money when you don't need to? We make 1000 hp on pump gas with less than 600 cubes.
Old December 16th, 2012, 08:14 PM   #9
moparhorse
moparhorse's Avatar
We make 2500 horse on alcohol with 572's. Alcohols cheap
Old December 16th, 2012, 10:24 PM   #10
Suta99
Suta99's Avatar
Just a FYI if you state something is run on 110 octane that is race gas. Alcohol is cheap but is not what you said this runs on.
What does this engine require to run? Alcohol or 110 octane gas
Old December 17th, 2012, 02:10 PM   #11
moparhorse
moparhorse's Avatar
It can run either if you wanted to. If somebody dont realize 110 is race fuel then they shouldent be buying a motor in the first place. Im sure you could make it run on lower than 110 but thats what i decided to run in it.
Old January 9th, 2013, 01:20 AM   #12
78mitsu
Still missing Moab
Default Interested
Interested in your big-block. Couple questions;
was everything Magnafluxed prior to build (General condition)?
Forged/HyperU Pistons?
Expected compression?
H-beam/I-beam Rods?
Head Casting (Open Chamber 049, Closed Chamber 290/702 ) Final CC after porting?
block Casting number?
Tins included?
In WI, Where -R-U?
Thanks,
78
78mitsu is offline   Reply With Quote
Old January 9th, 2013, 07:40 PM   #13
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Pm sent
Old January 10th, 2013, 10:31 PM   #14
78mitsu
Still missing Moab
Yes the block, crank and heads were magnafluxed before doing anything. The pistons are forged JE brand. Rods are h beam from eagle. The pistons are either 12 or 12.5 to 1.
Not sure on the numbers on heads or block. I will get back to ya on that. By tins do you mean oil pan, timing cover, and valve covers?
THX! that helps, yeah... oil-pan and valve covers.
Old January 12th, 2013, 04:14 PM   #15
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
casting # on the cyllinder heads?
Originally Posted by FlatFender View Post
America! Fuck yeah!
gofastbobby is offline   Reply With Quote
Old January 13th, 2013, 03:35 AM   #16
moparhorse
moparhorse's Avatar
Heads are open chambers, and are 049 numbers. Block casting number is 361959. 2 bolt passenger block, and says HI perf on back of block. Cam is comp cam part number 11-324-4 814 on rear of cam. Its a 3 bolt cam gear.
Old January 13th, 2013, 03:52 AM   #17
moparhorse
moparhorse's Avatar
Heres a good one if you looked up the numbers on the camshaft. It says its a hydraulic camshaft, and we ran solid lifters in it. Im not sure what happend. When we bought the cam it came with solid lifters, which I still have that I put in a box thats numbered for each cylinder so I could put them in the same place when put back together. It has a couple other numbers on back lobe of cam that are stamped in it. Not sure what they are?
Old January 14th, 2013, 08:12 PM   #18
biggs-cj
biggs-cj's Avatar
Still have it ?
biggs-cj is offline   Reply With Quote
Old January 29th, 2013, 07:53 PM   #19
Iggy
Iggy's Avatar
If parting out, I am interested in the crankshaft, sending PM
Iggy is offline   Reply With Quote
Old February 2nd, 2013, 05:44 PM   #20
moparhorse
moparhorse's Avatar
Crank sold and deal pending on connecting rods. Thanks Iggy
Page generated in 0.42532 seconds with 83 queries
