yj axle lengths - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2012, 05:38 PM   #1
Collin95yj
Collin95yj's Avatar
Default yj axle lengths
i have a 95 yj looking to get a dana 60 front and a 14 bolt rear. i need to know what length axles i should get for the yj, also its a 4 cyl with stock trans and T-case and id like to run 35-37 inch tires what gears should i look for for that setup.
Collin95yj is offline   Reply With Quote
Old November 7th, 2012, 06:04 PM   #2
Wramblerguy
Wramblerguy's Avatar
Well your stock axles are about 60" wide
As far as gears I would say minimum 4.88s with 35s and even lower with bigger tires
5.13s wouldn't be a bad idea with a 2.5
3rd generation jeeper
Old November 7th, 2012, 07:57 PM   #3
Collin95yj
Collin95yj's Avatar
Ok thanks for the info, big help
Old November 7th, 2012, 08:14 PM   #4
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
This is a subject that is mostly opinion. 10 different people will give you 10 different answers. A lot of it depends on what you are going to do with the jeep. Trails, dd, rocks, mud, ect.
Old November 7th, 2012, 08:37 PM   #5
Collin95yj
Collin95yj's Avatar
Dd, mud and later down the road rocks
Old November 7th, 2012, 10:51 PM   #6
Wramblerguy
very true but i did the math one day and 31s with 4.10 is about the same as 35s with 4.88s if that helps any
i know my 2.5 barely pulls 5th with 31s and 4.10s
Old November 8th, 2012, 07:22 AM   #7
Collin95yj
Collin95yj's Avatar
im not sure of the stock ratio but thats what i beleive is in the axles right now and it does fine with 30's... told my dad about the 4.88's and idk if hes gunna let that happen due to stress on the motor
Old November 8th, 2012, 07:57 AM   #8
Wramblerguy
A lower ratio in the axle makes for less stress on the motor because it makes it easier to get everything moving
And if you are thinking about on the highway if you have 37s with 4.88 your rpms will probably be lower
Do the math some times
I think part if my problem is the t5 transmission we swapped in has a higher overdrive plus the added wind resistance of a yj 4 inches higher haha
Old November 8th, 2012, 12:50 PM   #9
Collin95yj
Collin95yj's Avatar
headed to the local junk yards this weekend to look for the 4.88's
Old November 8th, 2012, 03:54 PM   #10
Wramblerguy
If you don't find them there I would recommend Ron's machine service, they are very knowledgable and have great prices too, I would recommend to call them to get the best deal
Old November 8th, 2012, 04:00 PM   #11
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
You aren't going to find a 60/14 bolt combo in the junkyard that is 60" wide. That would be custom width.
The narrowest stock 14-bolt is going to be one with C&C hubs at around 64.5" wide. The Front dana 60s that most want are Ford or Chevy and they are usually around 69" wide.
Page generated in 0.42310 seconds with 56 queries
