Tcase upgrade question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 6th, 2012, 05:36 PM   #1
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Default Tcase upgrade question
Ok someone that knows more about transmissions than me help me out please.
I need to upgrade my Transfer case.
I'm still running the 231 snapped an output shaft this past weekend.
What are my options for going bigger without dropping coin on a damn atlas?
I would like gear to gear I have a D300 in the shed but I don't think it will clear my trans.
Other thing is I like the gearing my rig has right now so I would like to retain that if at all possible.
1997 Dodge Dakota
5.2L V8
42Re Trans
231 Tcase
60, 14 bolt axles with 5:38 gears
43" Sx
Old November 6th, 2012, 06:16 PM   #2
hamsmotorsports
hamsmotorsports's Avatar
Atlas.
hamsmotorsports is offline   Reply With Quote
Old November 6th, 2012, 06:27 PM   #3
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Old November 6th, 2012, 06:37 PM   #4
joescamaro67
joescamaro67's Avatar
I have 5 or 6 of those outputs if you want some spares. I upgraded to a atlas and love it
joescamaro67 is offline   Reply With Quote
Old November 6th, 2012, 07:01 PM   #5
269bigoldodge
269bigoldodge's Avatar
np 241 hd
269bigoldodge is offline   Reply With Quote
Old November 6th, 2012, 09:31 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
most normal light duty dodges are 23 spline. should be a pretty straight forward swap.
you want a dld 241 (dodge light duty), not from a diesel or v10.
the case is physically bigger, tunnel or crossmember might need massaging.
check the speedo output, i think some are vss some are not.
i think the dodge 241hd is 27 spline.
Old July 31st, 2013, 06:42 AM   #7
TheDodgeGuy
PR MTU 4X4
TheDodgeGuy's Avatar
98+ have the speedo output on the rear axle, below that it is on the t-case but the sensor from the 241 should work.
TheDodgeGuy is offline   Reply With Quote
Old January 11th, 2014, 01:56 PM   #8
dirtpoor4x4
anti-jeep
dirtpoor4x4's Avatar
Trans out put shaft size is what would determine what trade you would want
dirtpoor4x4 is offline   Reply With Quote
Old January 11th, 2014, 02:16 PM   #9
curbdog17
Mini Van
curbdog17's Avatar
Originally Posted by Mr. Beefy View Post
JB Weld it.
Page generated in 0.28182 seconds with 50 queries
