94 7.3 idi maxi fuse 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2012, 10:06 PM   #1
heavy74chevy
heavy74chevy's Avatar
Default 94 7.3 idi maxi fuse 11
I have a 94 f350 idi turbo. I started my truck up at work as usual, everything worked as it should. Im cruisin down the road and about 20 minutes into my 30 min drive the truck just shut off. I didnt loose power to anything else, all lights still work radio and heater. Starter still cranks the motor over it just wont fire. In the fuse box under the hood maxi fuse 11 is blown. I rigged my fuel shut off solenoid with a wire to my battery and it starts and runs, but my wait to start light doesnt come on and when i replace the fuse it pops again. Is the glow plug relay on the same fuse as the fuel shut off solenoid and if my relay went bad could it cause the fuse to blow. I think the only reason it started with the wire is because it was still warm and didnt need the glow plugs. My guess is the relay but any help is appreciated.
heavy74chevy is offline   Reply With Quote
Old November 6th, 2012, 12:14 PM   #2
not sure
no wait! my name is joe
not sure's Avatar
I pulled a diagram and the fuses are labeled in letters not numbers so i dont know what circuit your talking about
not sure is offline   Reply With Quote
Old November 7th, 2012, 09:02 AM   #3
heavy74chevy
I found a diagram online and they use letters but on the under side of the panel cover they use numbers. I figured it out thought, it controls the fuel shut off solenoid the cold idle solenoid and the glow plug relay. I found a bare wire in the harness that was grounding out and blowing my fuse which in turn was shuting off my fuel at the ip. Taped it up and shes all better.
Page generated in 0.19668 seconds with 32 queries
