Cylinder leakdown test - Royal Oak - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 5th, 2012, 09:06 AM   #1
Rx7Kevin
Question Cylinder leakdown test - Royal Oak
My 85 suburban SBC is starting to burn oil, blue smoke likes to come out of the passenger side exhaust. Compression is the following (only checked the passenger side bank)
cylinder 2 = 180psi
cylinder 4 = 32psi
cylinder 6 = 12psi
cylinder 8 = 182psi
so now I'm looking at making sure I just need to do a simple fix or start a winter project.
Anyone got a cylinder leakdown tester or know a place where to get it done, the truck runs and starts and drives fine, its jut not very powerful, at least it has 4.10 gears :)
Rx7Kevin is offline   Reply With Quote
Old November 5th, 2012, 09:57 AM   #2
MilwaukeeF350
Dan
What happened if it running while you remove oil cap off valve cover? Smoke coming out?
With that low compression you could had bad rings on piston or blown head gasket. How long this issues been start?
Old November 5th, 2012, 10:34 AM   #3
Rx7Kevin
I haven't tried that but I will when I get home, but the issue is that the valve cover with the oil cap is on the other bank.
I'm thinking rings or stuck valve(s), as well as bad valve seals. A lot of vehicles with bad valve seals will give a good puff of oil smoke upon start up, but there is more than that going on providing those compression numbers lol.
When I pulled the plugs out on those middle cylinders there was oil on the threads. I'm still kinda putting this truck together/fixing it up. I purchased around May and I've maybe put 2000 miles on it. The engine is from another truck, its kind of a basket case so I'm not surprised if the engine will need a refresh.
Old November 5th, 2012, 10:57 AM   #4
in2deep
Hole tester
think you can get them from auto zone but the point ur at it dosent really matter i know on my commpression gauge i can pull the valve out of it and hook it up to a air compresser try that if you can
Old November 5th, 2012, 11:26 AM   #5
Rx7Kevin
I don't have an air compressor
but at least I'm not getting any coolant in the oil.
Old November 5th, 2012, 01:22 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
Originally Posted by Rx7Kevin View Post
cylinder 2 = 180psi
cylinder 4 = 32psi
cylinder 6 = 12psi
cylinder 8 = 182psi
Most likely the head gasket is blown between #4 & #6. Seen this happen in a few trucks.
Old November 5th, 2012, 04:16 PM   #7
Rx7Kevin
Yeah I have 3 theories:
1. bad head gasket
2. stuck valve
3. rings are toast
Old November 5th, 2012, 04:52 PM   #8
Paul04TJ
Small, but talented
Paul04TJ's Avatar
Dump some oil into the spark plug hole on the low cylinder and check it again.
Paul04TJ is offline   Reply With Quote
Page generated in 0.34684 seconds with 47 queries
