94 "ghetto" jimmy - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2012, 11:08 PM   #1
muddinman56
blood,sweat and beers
muddinman56's Avatar
Default 94 "ghetto" jimmy
plans to make it an budget rig. my first build so if any one has any help full tips for me thanks even tho its not a jeep. plans for right now is to keep the ifs if its all in ok shape, keep the 4.3 vortec. im not sure what trans or transfercase is in it but it runs great just has a vacuum problem and a little wire problem.
as of right now i need a drivers door and a passenger door panel.
if any one has parts for these things lmk
Old November 5th, 2012, 01:06 PM   #2
OL RED
workin hard to play hard
OL RED's Avatar
Send a message via Yahoo to OL RED
the only suggestion i have is keep the 4.3 as long as you can. especially if you plan on doin a sfa swap. i tried to do everything in one jump and wound up with nothing but alot of headaches.
good luck with the build.
OL RED is offline   Reply With Quote
Old November 5th, 2012, 06:04 PM   #3
muddinman56
I want to because for for it is it does have a lot of smoke the tires power. The guy I bought it from put almost 2000 grand into the motor and trans about 2-3 months ago.
I had the receipts but the drivers door dosent shut and when I turned the door swung open and I lost them.
Do you have and tips or hints on a sfa swap?
Old November 5th, 2012, 06:07 PM   #4
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
PM Wadey about the SAS. He did one on his ZR2 Blazer and he did an awesome job! He really knows his stuff!
Old November 5th, 2012, 06:10 PM   #5
muddinman56
thanks when I get around to doing the swap I will.
Old November 5th, 2012, 06:22 PM   #6
jaysusr
jaysusr's Avatar
I recommend spelling ghetto correctly.
Old November 5th, 2012, 06:23 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
if it's gonna be strictly a trail rig just gear it deep and that 4.3 will be more than you'll ever need.. I have yet to be "underpowered" in any terrain. as for that IFS if you plan on any lift just go SAS off the bat and save the time and money .
Old November 5th, 2012, 06:58 PM   #8
crazygrady127
crazygrady127's Avatar
X's 2 Wadey knows what has to be done , and how to do it without blowing a lot of money , that's his blazer my Jeep is sitting on in my avatar !!
Sent from BlackBerry using Tapatalk
Tear It Up - Fix It - And Do It Again
crazygrady127 is offline   Reply With Quote
Old November 5th, 2012, 07:06 PM   #9
muddinman56
yes mainly a trail rig maybe a dunes rig to
Old November 5th, 2012, 07:10 PM   #10
skife
skife's Avatar
FREAK was breaking D44 axle shafts with a 4.3, pretty sure his rig is still broken.
Old November 5th, 2012, 07:23 PM   #11
muddinman56
wow but i dont know if mine has the power to do that lol
Old November 6th, 2012, 12:49 AM   #12
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
Wadey has a small problem with shafts too but I think it's more his driving style.
If you are looking for a plan to follow on a trail/dune/DD rig than Wade's is hard to beat. It does well in all terrain, even the rocks.
Link to Wadey\\\\\\\\\\'s build
Blzr's is good too if you wanted to go leaf spring.
Link to Blzr\\\\\\\\\\'s build
BeaverTown is offline   Reply With Quote
Old November 6th, 2012, 12:36 PM   #13
OL RED
OL RED's Avatar
depends on what you use for a suspension wadeys setup is really nice, but wasnt in my price range especially after i bought the doubler. if you end up doing a leave sprung system with a tire over 36's try and get the front leafs front spring hanger as far forward as possible. my 38's hit my fenders until i cut and hammered the firewall back. also 56" chevy spring work well in the rear as the mount the axle 3" further back.
heres a build i looked at for ideas/solutions to problems.
http://www.s10forum.com/forum/f221/p...-s-ton-380311/
there is actually a few well built rigs in that site to look at for ideas. good luck with build
Old November 6th, 2012, 04:38 PM   #14
muddinman56
thanks for all the info and links
more pics
im guessing my vacuum problem^
a better picture
the other thing is im ballin on a budget also im looking for cheap 44 front and 60 rear. and possibly a cheap pipe bender
Old November 9th, 2012, 03:47 AM   #15
crazygrady127
[QUOTE=BeaverTown;3209545]Wadey has a small problem with shafts too but I think it's more his driving style.
Oh trust me its definitely Justin's driving style , he definitely drives it like he stole it , lol , that's for sure !!
As a matter of fact I believe he just had a 1340 , thick wall rear shaft built for it about a month ago cuz he managed to screw up another one , haha , but he said this one should last ?? I guess we will see ??
Old November 9th, 2012, 05:58 PM   #16
muddinman56
i has a question. would a dana 30 just be way to little for this?
Old November 9th, 2012, 06:17 PM   #17
BeaverTown
Cuck Fancer
BeaverTown's Avatar
All depends on your tire size and driving style. 33's and light foot it might hold up. 35's and bigger I would say no way.
Old November 10th, 2012, 12:33 AM   #18
muddinman56
im just looking for a cheap front axle lol. but right now i do plan on running 33s
Old November 20th, 2012, 01:14 AM   #19
crazygrady127
I know your only planning on running 33's on it but even 33's will stress out a stock D-30 especially if you put a locker in it , plus just like everyone else , when your 33's wear out , or even sooner , your going to be trying to figure out a way to put 35's under it !! So if your gonna do all that work of swapping everything out anyway then I wouldn't put anything less than a D-44 !! But that's just me !! For example , I did not buy a Rubicon so I had the D-30 open axel , so I got the D-44 and bought RCV's (awesome but $$$) , Poly sleeved it , put in Timken bearings & seals , 513 Superior gears , Crane diff cover , Dynatrac ball joints , welded C-gussets on it , ARB air locker , AEV flip steer kit , Poly tie rod , Poly draglink , Superior lower control arm skids , and I'm running 37's and I am Really happy with it -BUT- with all the money I spent to build a D-44 , I could of just bought a "Pro-rock 60" and probably saved money !! And I could go to 40" tires instead of being stuck with 37's !! All because I had 35's at the time and didn't put a lot of thought into the future !! Don't make that same mistake !! Just buy bigger than you need , instead of spending $$$ and building something smaller !!
Page generated in 0.62893 seconds with 81 queries
