460 mock up block - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 4th, 2012, 04:43 PM   #1
codymcvicar
codymcvicar's Avatar
Default 460 mock up block
Looking to see if anybody has a 460 mock up block
Just got a fox body mustang and I'm putting In a 460.
Just thought a mock up block would make things a little Easyer
Thanks!
codymcvicar is offline   Reply With Quote
Old November 4th, 2012, 06:06 PM   #2
cerial
Direct Drive FTW
cerial's Avatar
May want to put this in the wanted section.
If you have the engine you can make a mock up out of plywood copying the face and rear bottom and top then bolt the oil pan. It will be a cob job but I did one with a 350 once out of a sheet of plywood I had laying around. It weighed like 10 pounds and about 50 with the oil pan, some old stripped down Aluminum heads, and intake bolted to the plywood.
Yes I am cheap. You can also find a cast boat anchor and tear it down.
Maybe this guy still has these for like 200.
http://lansing.craigslist.org/pts/3300827778.html
Tear it down toss the bits in your scrap pile.
Old November 4th, 2012, 07:30 PM   #3
codymcvicar
Maybe I'll try that plywood idea.
Page generated in 0.59615 seconds with 32 queries
