I need some ideas - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 2nd, 2012, 09:52 AM   #1
Jeeper52
Budget, what budget?
Jeeper52's Avatar
Default I need some ideas
I bought a rear bumper for my yj off a friend and he made it to bolt on with 4 bolts on each side (which I like) My problem is that I need to copy the bolt patter on my plate ( which is off the jeep). the easiest answer would be weld it on. but I want it replaceable. The space between the bumper and the stand off is too short to get a pencil in to trace. If you dont get what Im talking about I will try to get som pics up tomorrow.
___________________
bumper
___________________
I I standoff
___I__I____
___________ bolt on flange
Last edited by Jeeper52; November 2nd, 2012 at 09:55 AM. Reason: the diagran didnt turn out right
Old November 2nd, 2012, 10:02 AM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
tape measure and sharpie? or you could get all fancy and use some poster board/cardboard and make a transfer template.
Old November 2nd, 2012, 11:47 AM   #3
Bones
Bones's Avatar
...this isn't a swiss watch. Cardboard template will work just fine.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 2nd, 2012, 11:53 AM   #4
KCameron13
Weekend Warrior
KCameron13's Avatar
This. A sharpie and a piece of cardboard works wonders. Simple, quick, easy, and accurate.
KCameron13 is offline   Reply With Quote
Old November 2nd, 2012, 11:59 AM   #5
dfm_13
dfm_13's Avatar
If its too tight for a sharpie I take needle nose pliers and pull the felt tip out of the sharpie. Then you have a sharpie that's about 3/4 of a inch long. It works great
dfm_13 is offline   Reply With Quote
Old November 2nd, 2012, 12:08 PM   #6
Nope, take accurate measurements, draw it up on CAD so you know exactly what you have and can duplicate it in the future.
Old November 2nd, 2012, 01:52 PM   #7
Wramblerguy
Wramblerguy's Avatar
Go old school and Put ur paper board up to the flange and use a ball pined hammer to tap out the holes
3rd generation jeeper
Old November 2nd, 2012, 02:08 PM   #8
Yep, that works well. A piece of white posterboard shows up nicely. Or put grease on the piece with holes, and then press it to the flat piece needed to be drilled. The grease will transfer over, and leave holes that you can mark and drill.
All kinds of things you can do. Clamp it in place, and use white out to mark. Use a metal handled disposable paint/acid brush, bent at a 90 degree angle to get in where you need it. (Or cut the end off a small paint brush and stick it at a right angle into a piece of dowel with a hole drilled in it).
Old November 2nd, 2012, 02:31 PM   #9
Jeeper52
Jeeper52's Avatar
I dont know what I was thinking. see, stupid people shoulnd't talk
Old November 2nd, 2012, 02:45 PM   #10
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
In this case you have to draw up the entire rear section of the jeep in CAD, right Jim?
Page generated in 0.32677 seconds with 53 queries
