Shackles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2012, 07:54 PM   #1
royalcherokee
royalcherokee's Avatar
Default Shackles
If I add shackles to my jeep will it mess with my pinion angle? I'm installing an sye and have my pinion angle perfect and want to add some more height to the rear but don't want to have to order more shims.
Any advice?
royalcherokee is offline   Reply With Quote
Old October 31st, 2012, 11:07 PM   #2
gli_ryan
gli_ryan's Avatar
Yes it will change your pinion angle. I've got my angle setup all eye balled essentially and have a super short driveshaft, no issues yet even at 50 (the fastest I've had it going since rebuild). You're not going to get hardly any lift out of shackles though, and if you do it's because you decided to get ones that are WAY too big and then you're going to have problems.
gli_ryan is offline   Reply With Quote
Old October 31st, 2012, 11:30 PM   #3
royalcherokee
Sweet thanks! Ill probly go with some add a leafs to boost it up an inch or so
Page generated in 0.21156 seconds with 32 queries
