snow tires on FWD car in SE Michigan - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2012, 08:49 AM   #1
kickstand
circling the drain
kickstand's Avatar
Default snow tires on FWD car in SE Michigan
Thinking about getting snow tires for the old lady. Her current all season tires that came on her car have like 10,000 miles on them, I just rotated them the other day and they have plenty of tread.
I drove my focus trhough the winter last year and had no complaints, but thought she may like the peice of mind/added safety of snow tires. She commutes about 65-80 miles per day.
Is it imperative to buy all 4, or will 2 for the front tires be enough to add a little help with braking and enough traction to avoid being stuck?
Old October 31st, 2012, 08:55 AM   #2
Spence1986
SlowBalt SS
Spence1986's Avatar
Send a message via AIM to Spence1986
After spinning out in my brothers car on M5, I recommend buying all 4 so that doesn't happen to anyone.
He was being cheap and only bought the front 2.
Spence1986 is offline   Reply With Quote
Old October 31st, 2012, 08:57 AM   #3
wakebabe
Mrs. Bones
Bill puts bliztech tires (??) on my Fusion - all 4's. They are awesome. I'm more comfortable driving the Fusion in the snow, especially slush across lanes, than any SUV I've had. And of course, I'm pretty sure he found them used on craigslist vs buying brand new.
wakebabe is offline   Reply With Quote
Old October 31st, 2012, 08:57 AM   #4
Immortal
NO RELIGION WAT!
Immortal's Avatar
I don't believe it is imperative. I have driven without snow tires for many years. Yes they do add traction, but if you don't drive a car to its full potential there really is no noticeable difference.
Tire manufacturer will recommend all 4 tires regardless of 2wd or 4wd.
Old October 31st, 2012, 09:00 AM   #5
mtnbikinbryno
mtnbikinbryno's Avatar
Send a message via AIM to mtnbikinbryno
You definitely want 4 for braking purposes, or the rear will lose traction faster and slide.
mtnbikinbryno is offline   Reply With Quote
Old October 31st, 2012, 09:03 AM   #6
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
You will definitely need all four. Having two different tires on the front and rear will drastically change handling capabilities, especially on snow and ice.
Old October 31st, 2012, 09:04 AM   #7
kickstand
circling the drain
kickstand's Avatar
I thought about that, but with all the stability controls and such its hard to even get the car sideways when trying, was adding them mostly to help get out of the neighborhood.
We don't really get that much snow anyway.
Old October 31st, 2012, 09:08 AM   #8
Nuggets
I fix stuff!
Nuggets's Avatar
Modern all season tires do a really good job handling the snow. I have them on my Contour and that stupid little car is like a tank. I would think if you went with a dedidicated tread pattern like an agressive snow tire you would sacrifice dry/wet weather braking because of less surface area contacting the road.
Old October 31st, 2012, 09:08 AM   #9
seadooxpguy
seadooxpguy's Avatar
Some bigger tire store chains (like Discount) will NOT install 2 snows on just the front.
Plus, if you get 4 and rotate them like you should, they will last for twice as many winters
seadooxpguy is offline   Reply With Quote
Old October 31st, 2012, 09:15 AM   #10
kickstand
circling the drain
kickstand's Avatar
yes they do, for you and I.
for the lady, snow tires are a worthwhile investment.
Old October 31st, 2012, 09:20 AM   #11
dreezy
Haggard Fab
dreezy's Avatar
I loved my blizaks and even the hankooks that I had on my altima.
Def don't do just two on the front though. When I worked at discount we would only do two if they went on the rear. Reguardless of fwd or rwd.
Old October 31st, 2012, 09:21 AM   #12
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
I would do all 4, but they would be 285/50/17. Gonna do it, do it right.
zook94 is offline   Reply With Quote
Old October 31st, 2012, 09:29 AM   #13
DarrinGT
DarrinGT's Avatar
As most said, do 4, Well worth the investment.
I did these on my wife's Subaru years ago, and was totally convinced on Snows, It made her a Confident Winter Driver. Now I have 4 snow tires mounted on rims for all of our cars, Her Jetta TDI, My Passat TDI, My Plow Truck, Daughters Saab, and Sons Volvo. Wont go through another winter without them.
Keep an eye out on Craigslist, you can pick up a set of four that have been used for one season for 1/2 price of new.
DarrinGT is offline   Reply With Quote
Old October 31st, 2012, 09:45 AM   #14
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
If the stability control works that good on ice don't waste the money. If it doesn't which we know is the case, get all 4. If you do only get two I would put them on the rear.
You can control the front by turning the wheel and working the throttle, once the rear breaks traction there isn't much you can do to correct it, so may as well make it harder to break loose in the first place.
Blue XJ is offline   Reply With Quote
Old October 31st, 2012, 09:48 AM   #15
bdd1469
bdd
bdd1469's Avatar
I learned years ago to put the best traction in the rear of a fwd.When you turn a corner on a slick surface the rear will slid out every time.My good freind manages a discount tire and that is there policy also.All four new,matching tires or new tires on the rear only.
Old October 31st, 2012, 09:57 AM   #16
fsumotorhead
N8KVB
fsumotorhead's Avatar
x3 on the rear placement if only buying two.
The momentum during a turn causes the rear of the car to accelerate laterally during a turn, you definatly want the best traction on the rear.
Old October 31st, 2012, 10:04 AM   #17
Bones
Bones's Avatar
you are going to want all 4. We bought ours off cragislist 3 years ago from someone that turned in their lease. Best money ever spent. The Fusion handles snow/slush better than any 4wd SUV or pickup I've ever owned. Road trips in a blizzard aren't an issue.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 31st, 2012, 10:06 AM   #18
kickstand
circling the drain
kickstand's Avatar
Nothing works on ice, but the stability control in the focus is annoying as shit, it can't be turned off, and it is very agressive, ANY sort of aggressive driving in the rain or snow causes it to kick on VERY early, it works pretty damn well, but god I hate it.
I am hoping someone comes out with a chip to turn it off, you couldn't even take this car to a track day, although it is a decent handling little car (could be better, but the point remains) the stability control will kick on pretty quickly even when pushed on dry pavement around a corner.
Anyway, I see zero point in putting snow tires only on the rear in this car, the rear end never comes around, even when I e brake it around corners as soon as the e-brake is released the stability control straightens the car right out on snow. I thought maybe putting them only on the front would help for getting out of the neighborhood. But having them matched front to rear makes sense.
Old October 31st, 2012, 10:14 AM   #19
BooGTS
Boost Withdrawl
BooGTS's Avatar
All the best stability control doesn't mean shit if the tires aren't reacting with the pavement. I just scoured craigslist daily for a month. Got 4 2 piece BBS wheels with near new snow tires for $200 after the girl wrecked her Jetta (not in the winter, not with those wheels). The wheels alone were worth way more than that.
edit: Even have snows for the XJ. Bought a set of XJ Limited Icon wheels off here for $200, and for $79 a tire plus mounting I don't use the 4x4 unless I want to play and I stop quickly enough that I only worry about being rear ended.
BooGTS is offline   Reply With Quote
Old October 31st, 2012, 10:55 AM   #20
DuffMan
Your Message Here
DuffMan's Avatar
Had excellent results with the Hankook Blizzak knockoffs.
Page generated in 0.63130 seconds with 82 queries
