89 k 1500 help wont start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 23rd, 2006, 10:04 PM   #1
carguy64744
Default 89 k 1500 help wont start
wont start doesnt to much but the engine turns over has fuel spark compression just wont start any ideas thanks
carguy64744 is offline   Reply With Quote
Old October 23rd, 2006, 10:17 PM   #2
boggin-machine
boggin-machine's Avatar
soands weird coming from me but english may help other understand what is going on. you sure all cylinder have fuel and compression and spark. timing might be off. what motor is im assuming a 5.7 350 but it could nbe the 305 with the data that you posted
Old October 23rd, 2006, 10:41 PM   #3
user name
keep your stick onthe ice
user name's Avatar
fuel compresion and spark are the bieg three. is it getting to much fuel? does it back fire and have you changed anything since it last ran?
Old October 24th, 2006, 07:12 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
first off pull the aircleaner and shoot it with ether. If it starts it is fuel related. if it doesn't then report back and will go from there.
Old October 24th, 2006, 09:19 AM   #5
carguy64744
tried starting fluid no luck its a 350 doesnt backfire every once it a while it acts like it wants to start but thats it the rest of the time it doesnt do anything
changed plugs cap rotor and module because it wasnt getting spark now it is getting spark
Old October 24th, 2006, 11:34 AM   #6
KILLER"B"468
Yankabilly
you tried the ether before or after you got spark? if before try it again. If it was after then, do you have the spark plug wires on in the correct firing order? Is the spark bold and blue? or is it weak and red? If it is weak and red you may need to replace the coil as well. Just because there is spark doesn't mean there is enough to run the engine.
Old October 24th, 2006, 12:05 PM   #7
carguy64744
after i got spark it is blue never changed the wires around but i checked them and where right tried a new coil just now no luck hooked it up to a computer doesnt show anything wrong
Old October 24th, 2006, 12:24 PM   #8
KILLER"B"468
Yankabilly
It may sound goofy but I have seen spark out of the wires with a broken missing tip of the rotor. Check that and make sure it is on correctly.
If good then with the cap off have someone turn the engine over. Look to see if the rotor turns smooth and evenly not jerky.
Also you said it had compression can you post the #'s
Old October 24th, 2006, 12:44 PM   #9
carguy64744
looks to be fine rotor is new
Old October 24th, 2006, 12:55 PM   #10
KILLER"B"468
Yankabilly
Has the vehicle sat for a long time or just out of the blue doesn't want to run?
Also do the compression check and post the results for each cylinder.
Old October 24th, 2006, 12:56 PM   #11
Budman
Miss Budweiser Revealed!
Budman's Avatar
If that is a 5.7 Vortec, check your cap and see if it is inverted 180 degrees, I have a K3500 and the cap that's on mine is able to be done so it can screw not only the rotor but also firing order positioning. Other thing is get some dielectric grease and coat not only the plug wire ends but the cap ends as well, you'll have far less trouble in the future.
I had odd stuff going on for a while normally if the truck sat for a day or two then it would just roll and take forever if it would fire at all, otherwise drained the battery, wound up being corrosion on the terminal in the cap and wires, check your wires for corrosion where they plug into the cap, you've replaced everything except them so I'd check there as well.
In the mean time grab a
Budman is offline   Reply With Quote
Old October 24th, 2006, 01:02 PM   #12
carguy64744
it sat for a while drove it for a few days then it started acting up
Old October 24th, 2006, 11:28 PM   #13
carguy64744
well got it started i turned the distributer a little bit and it started runs
Old November 2nd, 2006, 02:15 AM   #14
carguy64744
well jumped time again put a new timing chain on it the old one was real bad runs great now
Old November 5th, 2006, 08:40 PM   #15
carguy64744
well wont start again no fuel or spark now im thinking short somwhere
Old November 11th, 2006, 10:05 PM   #16
carguy64744
fixed it ground wire on the thermostat housing was shorting
Page generated in 0.31538 seconds with 71 queries
