garage heater help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2012, 06:46 AM   #1
RADRICK
RADRICK's Avatar
Default garage heater help
I have a sterling hanging forced air/LP furnace. Last year all was fine, this season I turned up thermostat, and nothing happened. I assumed I had a bad thermostat. I bought a new basic dial honeywell, same type I was using before. I unhooked the 2 t-stat wires from the old t-stat, jumpered the two wires and the furnace kicks on like normal, ok now I know wiring/furnace is good. I wired new t-stat, now furnace wont turn on again no matter what temp setting. It is a basic 2 wire setup for thermostat, I tried switching the red/white wires just to see if maybee something got switched, still nothing. I called honeywell tech support, they were no help, said it has to be a wiring problem. It works when jumpered, doesent work with thermostat. From what I can tell the t-stat just makes or breaks the circut. Is there anything else the t-stat does, what am I missing here?
Old October 30th, 2012, 07:00 AM   #2
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Nothing thats it. Take it back and get a new one. I assume you have a mercury filled one. I have had those go bad.
tcxtreme1000 is offline   Reply With Quote
Old October 30th, 2012, 07:09 AM   #3
RADRICK
RADRICK's Avatar
I dont know if it is mercury filled or not, the orignal thermostat has a mfg. date of 2006.
Old October 30th, 2012, 07:39 AM   #4
tcxtreme1000
hhhmmmmm
Page generated in 0.20196 seconds with 34 queries
