93 slivrado problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2012, 08:23 PM   #1
muddinman56
blood,sweat and beers
muddinman56's Avatar
Default 93 slivrado problem
ok i have a problem with shaking when im going about 40-45 and i hit the breaks it shakes not real bad but i want to fix it i dont think its just a bad rotter but i dont know
thanks matt
Old October 29th, 2012, 08:27 PM   #2
deerebowtie
Unchained
deerebowtie's Avatar
most 20 year old trucks are rotters.
Old October 29th, 2012, 08:44 PM   #3
muddinman56
Old October 29th, 2012, 08:45 PM   #4
muddinman56
not this one zero rust
Old October 29th, 2012, 09:55 PM   #5
in2deep
Hole tester
call bs on zero rust, but anyway rotors could be it but it would do it at any speed, worn steering components can do it to,
Old October 29th, 2012, 09:59 PM   #6
muddinman56
it really is hard to explane but it dosent shake the steering wheel at all just shakes the truck and for real no rust it does have some in the bed but not much b4 i rino lined it
Old October 29th, 2012, 10:11 PM   #7
GREASYHANDS
GREASYHANDS's Avatar
Well if its not the front it must be the rear.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 29th, 2012, 10:17 PM   #8
muddinman56
my dad said it could be the drums or the old shoes so i pulled the drums they look fine the shoes were cracked and one spot were broken so replaced did nothing but improve stopping. it feels like its comeing from the front i replaced the front shocks but if the shock is blown out would that make it happen? also would worn rear leaf springs and bad rear shocks make it shake?
Old October 29th, 2012, 10:19 PM   #9
muddinman56
o ya i also feel to break peddle vibration or any thing
Old October 29th, 2012, 10:32 PM   #10
Toivo
Feel lucky?
Toivo's Avatar
Front rotors are warped. Replace pads and rotors in the front and make sure the calipers retract properly. If they do not retract smoothly, replace or rebuild them. Further, your truck has ifs, if the suspension bushings are toast, you can transmit some nasty vibrations to the chassis/body from the control arm slopping about.
Old October 29th, 2012, 10:37 PM   #11
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
I'm gonna guess that you have the t-bars cranked up, you probably have some bushings that are rotted out, like the control arm bushings. Probably just about all your suspension stuff on the front is junk, depending on how long it's been cranked up.
If it's not the brakes, then make sure your wheels are balanced right and all the lug nuts are tightened properly as well
Old October 29th, 2012, 10:38 PM   #12
muddinman56
ill deffently be getting new rotors tomorrow then and checking the bushings while im at it and thank you for the imput guys i wasent sure and would rather have an idea then be buyin a boat load of stuff and chasing the problem
Old October 29th, 2012, 10:39 PM   #13
GREASYHANDS
You can't tell if the drums are out if round by eye balling them. If you feel pulsation in the brake pedal and the entire truck shakes when using the brakes replace or machine the rear drums.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 29th, 2012, 10:40 PM   #14
muddinman56
the bars arnt cranked up i bought it off an old man who bought it brand new in 93 but it does seam to sit higher then my buddys 99 k1500 (same body style as mine) but just a couple inches at most
Old October 29th, 2012, 10:41 PM   #15
muddinman56
thats what had me confused i have no pulsation in the pedal
Old October 29th, 2012, 10:45 PM   #16
GREASYHANDS
Then start speaking English!
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 29th, 2012, 10:51 PM   #17
muddinman56
my bad i didnt proof read that one
Old October 29th, 2012, 11:06 PM   #18
silveradoboy
Sam Brown
silveradoboy's Avatar
Doesnt look like you proof read any of your post. Holy shit, it is spelled Silverado btw!
silveradoboy is offline   Reply With Quote
Old November 1st, 2012, 12:49 PM   #19
TboneK1500Z28
yea your typing isnt helping us diagnose this at all.
so from my understanding when you hit the break it doesnt get better nor worse and its all the time during driving?
doesnt seem like its brakes, so its either front suspension or something in the rear
id jack the truck up and start checking your whole front end comonents, bushings,steering etc.
if that doesnt seem to be it check rotors just to be sure. and if that doesnt work start checking out the rear. its possible that you have a bent axle shaft but unlikely, cant say it cant happen though.
TboneK1500Z28 is offline   Reply With Quote
Old November 7th, 2012, 01:19 PM   #20
wilesin
10ptbuck
wilesin's Avatar
Any luck with this yet. Could possibly be a front axle shaft that has a bad joint.
wilesin is offline   Reply With Quote
Page generated in 0.27229 seconds with 83 queries
