4l60e to 700r4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 29th, 2012, 04:41 PM   #1
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
Default 4l60e to 700r4
i currently drive a 94 chevy pickup and destroyed the transmission. is is possible to run a700r4 if the computer is swapped for one from a 89? or do i have no choice hut to replace it with another 4l60e?
scare-crow is offline   Reply With Quote
Old October 29th, 2012, 04:49 PM   #2
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
You can swap the two, but your making a lot more work for yourself, you can find a good used 4L60E for a couple hundred bucks
You'd have to put on a TV cable too to shift the 700, as well as the computer, honestally i'm not really sure if that would work completly anyway....just pick up a new E
wave_crusher is online now   Reply With Quote
Old October 29th, 2012, 05:20 PM   #3
wave_crusher
I'll Direc your TV
Ok, the fact that you have no idea what I'm taking about says you should not try to swap the two transmissions
On pre '93 transmissions (4L60 and 700-R4) the transmission was shifted using a TV, or Throttle Valve cable, that cable is what told the transmission when to shift gears and when to down/up shift for passing, etc. '93 and up (with the introduction of the 4L60E) the transmission now used a solenoid to shift gears, which had a wire harness replace the TV cable. The old TV cable was used because the older style transmission was shifted hydraulically
You can bolt up the 700 in place of the 60E all day, but that doesn't meant it's going to work
Old October 29th, 2012, 05:26 PM   #4
scare-crow
the eskimo bro
scare-crow's Avatar
shifting the transmission is not the issue. i was not clear at first. i just want to eliminate the 60e. the 700 will be shifted manually.
Old October 31st, 2012, 11:01 AM   #5
chevytothelevy
like a rock
chevytothelevy's Avatar
fye they still used the 4l60 in the 94 but only in the 4.3 model i had a 94 stock with the 4l60 and found out the hard way....
chevytothelevy is offline   Reply With Quote
Old October 31st, 2012, 01:37 PM   #6
Bleay
sick of jackstand wheelin
Bleay's Avatar
What is your reason for wanting a 700r4?
Bleay is offline   Reply With Quote
Old October 31st, 2012, 02:02 PM   #7
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
you install a TransGo 4l60e-3 kit and shift a 4l60e manually. it removes all the electronics.
Old October 31st, 2012, 02:04 PM   #8
deerebowtie
Unchained
deerebowtie's Avatar
probably not wanting to spend the cash?
luckily this is TBI. you'll need a tv cable, re-hook up the VSS in the t-case so you have your speedo. Physically there shouldn't be any d/s mods necessary. tape the 4L60E wires up to keep dirt out of the plugs.
are or aren't you going to run a lockup converter? that's the only other bit.
Old November 1st, 2012, 11:43 AM   #9
TboneK1500Z28
keep a 4l60e, lot harder and more expensive to put a 700r4 in with absolutely no gain whatsoever.
TboneK1500Z28 is offline   Reply With Quote
Page generated in 0.27747 seconds with 50 queries
