2500hd headlight problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2012, 08:19 PM   #1
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Default 2500hd headlight problems
This seems to be happening on trucks from the 2003-2007 classics year range.
I have been reading alot about this and everyone who has the problem has the same symptoms.
Starts out as the passenger side low beam either dim or all the way out, then both low beams are intermittent and they either work or don't. Its very random and i cant reproduce it.
The Fog lamps and high beams still work 100 percent of the time.
Things i have done to try and reproduce or fix the problem so far and i have not been able to figure it out.
- changed fuses and relays
- changed head lamp switch
- sprayed water on the harness and all over under hood.
- shook the wiring harness looking for shorts
- removed Power distribution panel and inspected
- tilted steering column and tried to make lights not work
So far nothing has worked and i can neither reproduce the problem or get the lights to come back on when they are not working.
any suggestions?????????
Old October 28th, 2012, 08:40 PM   #2
Dylan
Dylan's Avatar
ours was the pigtail for the light socket. The one that splits to the high and low. Our has a plow harness so I'm not sure if this is your problems but those are the same symptoms as ours had.
I had to clean the terminals and use a dielectric grease on it.
Old October 28th, 2012, 08:47 PM   #3
blownexploder94
Todd
blownexploder94's Avatar
Have to tried having it plugged into a scanner like a tech 2, the lights are tied into the Body control module, Sometimes they will throw codes.
Name:	headlight diagram.jpg
Old October 28th, 2012, 08:51 PM   #4
hosejockey4506
Visiting Admin
I disconnected the Plow harness first thing thinking that was the problem
Old October 28th, 2012, 09:34 PM   #5
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I will ask around.
Old October 28th, 2012, 09:38 PM   #6
koochman450r
koochman450r's Avatar
A dim headlight is a ground issue. So make sure to check the grounds.
you won this battle.
Page generated in 0.23636 seconds with 42 queries
