welding chromo shafts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 27th, 2012, 08:32 AM   #1
welderbrian
welderbrian's Avatar
Default welding chromo shafts
My question : is there any special process for welding the caps in ujoints.
This is front axle shaft by the way. I have welded the caps on my stock 44 shafts with moderate success, it worked but eventually cracked and pushed the cap out anyways, so I upgraded to chromo shafts and have had good success, but my last wheeling trip I pushed the cap out on the short side inner shaft, and before I realized what had happened it egged out the hole a little, Id like to get a little more life out of it.
I know that chromo tubing needs to be tig welded, because of the heat of mig welding causing it to become brittle and crack.
I dont want to mig weld it and end up making it weaker, and it end up breaking an ear off and damaging the chromo stub shaft.
welderbrian is offline   Reply With Quote
Old October 27th, 2012, 08:58 AM   #2
Tab
Tab's Avatar
If its already egged out then go ahead and weld it because its pretty much done. You can mig it but try not to put too much heat I to it so you jack up the ear or burn out all your grease. Do you run full circle clips? If you have cro-mo shafts and run full circle clips you shouldn't have the caps walking out.
Old October 27th, 2012, 09:41 AM   #3
welderbrian
Yes full circle clips, and I also run a spool in the front which I know isn't helping everything survive, but wheeling is alot more fun spinning all 4.
Old October 27th, 2012, 10:42 AM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
Weld a strap across the cap (welding on the ears of the yoke only).
Good luck.
Old October 27th, 2012, 10:45 AM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
If it's in the budget, consider running a Detroit Locker in the front. I've done it and I've had zero issues with hard steering or excessive noise. I used the Quite Locker when I did it and you could never really tell it was there. Worked great with 54" tires and a retarded driver.
Old October 27th, 2012, 11:50 AM   #6
welderbrian
Detroit is not in budget, I don't know possibly I'm not getting clip in groove all the way, seams weird I'm only having problem on short side.
Old October 27th, 2012, 04:28 PM   #7
trailtwister
Don't Insult My Stupidity
trailtwister's Avatar
Try JB weld - no heat
trailtwister is offline   Reply With Quote
Page generated in 0.29320 seconds with 44 queries
