CO2 On board air setup question? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 26th, 2012, 12:41 PM   #1
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
Default CO2 On board air setup question?
I am currently working on building a CO2 on board air system and was wondering from those of you running this kind of system if the gauges are really necessary? I was reading a build your own system and it was mentioned that the gauges are pretty much useless and just get an preset regulator for it.
Also is there anything that needs to be to a CO2 to convert it to run Nitrogen?
Thanks.
mudviper is offline   Reply With Quote
Old October 26th, 2012, 01:01 PM   #2
I have two. Neither has a gauge.
Old October 26th, 2012, 01:27 PM   #3
Dylan
Dylan's Avatar
I have a high side gauge, low side gauge and regulator. I guess it depends on what you are doing with it. The high side gauge is nice to let you know when you are about to run out. You could always just weigh your tank full and empty and there you have your scale.
Old October 26th, 2012, 01:28 PM   #4
montecarlo33
The Violator
montecarlo33's Avatar
I have 1 with a gauge. Only thing I use it for is to tell me when its about to run out. Just before it runs out, my gauge anyways goes UP 10 or so lbs from the normal and I know im getting close to running out. Besides in that they are worthless IMO
Old October 26th, 2012, 02:26 PM   #5
mudviper
getting dirty
mudviper's Avatar
I was reading that the gauge will always say full until it is just about empty due to the fact that the tank stays at a constent pressure
Old October 26th, 2012, 02:38 PM   #6
Brian81CJ
Sellin' it all!
Brian81CJ's Avatar
True. There is only a VERY short amount of time that the gauge will start dropping. At that time, the tank will be empty of liquid CO2 and you will only have a tank full of gas. Tank pressure gauge is useful when it's very cold outside and tank pressure may be too low to fill tires or run tools. As well as if the surrounding temp is too high and tank pressure starts rising allowin you to move it to a cooler location so the safety valve doesn't release the CO2.
If you simply want to fill tires, the preset reg is great. If you want to do other things like running air tools and such, then go with an adjustable one.
Brian81CJ is offline   Reply With Quote
Old October 26th, 2012, 02:43 PM   #7
If you simply want to fill tires, the preset reg is great. If you want to do other things like running air tools and such, then go with an adjustable on.
Who are you to quote this dribble?
For those who don't know, Brian was the owner of Ultimate Air. Both of my tanks are from him. I only wish he was still in business. His answers are from a manufacturer, not opinon like the rest of us.
Old October 27th, 2012, 01:34 PM   #8
cerial
1200PSIg Double acting
cerial's Avatar
Just weigh empty then full and write the weights on the side. Then you can use a scale of sorts to get a very close idea how much use you have left. So much easier and accurate then any gauge that you will install.
Old October 27th, 2012, 04:07 PM   #9
phittie1100
phittie1100's Avatar
I like my gauges - I sometimes run air tools from my tank instead if running 150' of hose from the compressor in the back garage, and use it for shielding gas on my MIG.
Sent from my DROIDX using Tapatalk 2
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline   Reply With Quote
Old October 27th, 2012, 04:15 PM   #10
Tizken
Thanks.
Nitrogen tanks have a much higher pressure, it would be a different regulator. Also on a nitrogen tank the tank gauge is useful since the pressure drops as you use it up.
Tizken is offline   Reply With Quote
Page generated in 0.24373 seconds with 53 queries
