Excessive compression? Volkswagen. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 24th, 2012, 03:29 PM   #1
GREASYHANDS
GREASYHANDS's Avatar
Question Excessive compression? Volkswagen.
01 VW Jetta. 2.8 vr6.
Misfires on cyls 1,3,and 5. Valve train rattle and cam position error code. Bank one compression shows 200+. Bank 2 consistent at 160#.
Other codes for knock sensor circuit high. I assume due to the engine noise. Just came from the dealer for a drive by wire repair. Looks like they replaced two wires from the throttle body to the pcm.
Sounds like it jumped time or a chain is loose. What next, Tear it open?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 24th, 2012, 03:52 PM   #2
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
Doesn't that have a timing belt? How many miles.
samurai2240 is offline   Reply With Quote
Old October 24th, 2012, 04:13 PM   #3
capone
capone's Avatar
Yes it has a timing belt not a chain.
capone is online now   Reply With Quote
Old October 24th, 2012, 04:44 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
It sounds like the belt jumped a tooth or two letting the compression build more since the cam timing is off.
Old October 24th, 2012, 06:34 PM   #5
GREASYHANDS
The motor has a timing chain and 130k miles.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 24th, 2012, 08:01 PM   #6
GREASYHANDS
Volkswagen's suck
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 24th, 2012, 09:08 PM   #7
Nuggets
I fix stuff!
Nuggets's Avatar
I'd look at valve train and check it's movement.
Old October 24th, 2012, 09:55 PM   #8
bdd1469
bdd
bdd1469's Avatar
Sounds like it jumped time.Vw's are known for it,and they are interference motors,so you most likely bent valves.Sorry to say but you are going to spend a lot of money to fix it.
Old October 25th, 2012, 07:24 AM   #9
GREASYHANDS
Looks like I get to strip the front end off just to access the intake bolts. Yippee.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 25th, 2012, 07:34 AM   #10
frdboy
frdboy's Avatar
Has a chain and it probably had a tensioner fail and jumped a tooth. Maybe another person that thinks oil changes are silly and a wate of money.
Time to take it apart.
Old October 25th, 2012, 09:20 AM   #11
bdd1469
bdd
bdd1469's Avatar
I dont care how often you change rhe oil,vws jump time,all the time.The turbo charged beattle motors call for the belt to ve changed at 60,000 miles.I have seen several that broke before 50,000. It is easy to spend $1500 just repairing the 5 valve head.That doesnt include labor to pull and reinstall it,or any other damage the engine may have suffered.
Vws are exspensive to own unless new.
Old October 25th, 2012, 09:43 AM   #12
frdboy
frdboy's Avatar
I was just going be the info supplied, sounds like a chain issue. These had alot of trouble with the upper chain tensioners and chains stretching. We see chain tensioner issues on alot of different brands and normally upon disassembly, plugged/restricted passages are what we find.
Old October 25th, 2012, 10:14 AM   #13
GREASYHANDS
Totally different engine. But thanks for the read.
This one appears to have 2 chains, one upper and one lower. The bitcha about it is they are on the back of the engine. Looks like its time to call the junk yard.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 25th, 2012, 11:04 AM   #14
Dylan
Dylan's Avatar
LOL, this is funny because I just helped replace a timing set on an exact same car. You think it's a bitch to pull the front clip to get the intake off? That's about the easiest part of the job. you have to drop the trans to get at the chains.
you can pull the intake and valve cover and set timing to verify both cams are still in time. It it jumped a tooth, you should still be ok (especially seeing how you have compression still). The car I worked on had the lower chain snap (it was a new chain about 30K miles on it, 2nd chain).
Old October 25th, 2012, 03:32 PM   #15
GREASYHANDS
That's what happened to this car a while back. Now I'm stuck working on the replacement, and a warantty is now involved. This could take day's.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 25th, 2012, 04:03 PM   #16
curbdog17
Mini Van
curbdog17's Avatar
Have you tried jamming a finger or two up your ass?
Old October 25th, 2012, 04:48 PM   #17
jbsjunk
Little Member
jbsjunk's Avatar
It'll fit beside the broom his boss shoved up there. Bristles first.
Old October 25th, 2012, 04:49 PM   #18
montecarlo33
The Violator
montecarlo33's Avatar
Originally Posted by jbsjunk View Post
Bristles first.
ouch. sounds painful
Old October 25th, 2012, 06:14 PM   #19
GREASYHANDS
Never mind the things I keep in there, its nice to be able to find what I need.
Butt yes curb, I did try that a few times with no luck
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 25th, 2012, 06:57 PM   #20
firehawk
Live Action!
firehawk's Avatar
I F'in hate working on VW'z, they piss me off. I want to punch every German in the face for how those engineers design that shit. I tried to tell my boss that I don't work on Vw'z after I was assigned one, he told me I work on anything they pull into my work stall, he was right but luckily it was an easy job.
Page generated in 0.40576 seconds with 83 queries
