K5 Land Yacht Build - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2013, 10:43 PM   #101
89TBIguy
slowly but surely
89TBIguy's Avatar
Here a shot of the final shackle angle with the weight of the truck on the springs. Front spring eye is in the second hole of the b52 kit and rear hanger is in the stock location. Looks to be ok maybe a little far back, but after doing some jack flexing I don't think it will bottom out on the frame...
89TBIguy is offline   Reply With Quote
Old March 6th, 2013, 10:56 PM   #102
89TBIguy
slowly but surely
89TBIguy's Avatar
Originally Posted by Deuling View Post
Do the DIY4X. You wont be let down.
And just let me know on the sheet metal. Just dont dent it to hell before hand lol.
Will do, spring is on it's way so ill probably be doorless until fall anyways, they are placed in protective quarantine, and by that I mean they are collecting dust next to my 3D bow targets, until I decide on boat side height. Luckily for you jackstand wheeling is pretty mild when it comes to body damage
Old March 7th, 2013, 04:02 PM   #103
bud442
bud442's Avatar
Nice build!
bud442 is offline   Reply With Quote
Old March 11th, 2013, 05:09 PM   #104
89TBIguy
slowly but surely
89TBIguy's Avatar
Appreciate it, yours looks very clean...
Old March 11th, 2013, 05:16 PM   #105
89TBIguy
slowly but surely
89TBIguy's Avatar
Well im back up at school so I figured id finish posting up everything I got done over spring break.
Had more issues with the sending unit I bought. Tank has been out and in 4 times now twice for the shackle flip and twice for a non-reading gas gauge turns out I had a bad unit, its all good now. Ive done this to many times ha
Old March 11th, 2013, 05:21 PM   #106
89TBIguy
slowly but surely
89TBIguy's Avatar
With my new springs came new flex so off the the parts store for more new brake stuff..
And no that spaghetti shaped hard line is not staying that, I couldn't find my flaring tool and needed to get the truck moving...
Old March 11th, 2013, 05:29 PM   #107
89TBIguy
slowly but surely
89TBIguy's Avatar
Back to the steering box from hell, after dropping the worm gear out of it and only finding 22 ball bearings i was afraid it would no longer work, it did. But the splined shaft that connects to the rag joint was a different size.
Ended up swapping out the valve out of my 4wd box and it still worked even though there were some differences. In addition my box uses flare fittings instead of the o ring style my old box used. Lucky for me im at the local parts store so much they give me a ton of parts to take home and try and then I can buy what fits
Ended up taking 4 trips, a piece of a brake line and a whole new line they made up for me while I waited.
Old March 11th, 2013, 05:41 PM   #108
89TBIguy
slowly but surely
89TBIguy's Avatar
Got that bolted on and bled as well as the brakes. It still leaks out of the seal near the sector shaft but a donor seal from my old box shout fix that. Its gotta come off anyways for my ord steering box brace as the amount of frame flex in that area is scary.
Still have yet to mount my ram and get hydro lines made but hell must have frozen over cuz she is off jackstands and actually moved this week. Even though it was only with front wheel drive
My fun was ended in a effort to keep the lawn intact, the steering box started leaking and with the red labels any flexing or hill climb turned into a front dig
Old March 11th, 2013, 05:52 PM   #109
89TBIguy
slowly but surely
89TBIguy's Avatar
Got that wrapped up Friday night and helped my dad and brother finish up the new workbenches. The barn is getting a cement pad as soon as the ground stops heaving and a lift mid summer. He either feels bad for me rolling around on old carpet and rocks or wants to build another jeep, im assuming the latter but im fine with it either way
Old March 12th, 2013, 06:12 AM   #110
Deuling
Sand Slut
Deuling's Avatar
Awesome. Lifts rock
Deuling is offline   Reply With Quote
Old March 12th, 2013, 10:26 AM   #111
89TBIguy
slowly but surely
89TBIguy's Avatar
They sure do, I cannot wait!
Old March 16th, 2013, 03:11 PM   #112
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
So by next Friday....
Trim fenders
Install hitch
Install tow hooks
Get hydro lines and bleed the system
Get a drive shaft from a _____ F250 Post a want add!!
Things that would be nice to have..
Plate the frame
Rig up a center limiting strap
Install the top/doors
Anything else?
Old March 16th, 2013, 04:21 PM   #113
bud442
bud442's Avatar
keep going man! between you and Deulings K5, I have started back working on mine..
Old March 19th, 2013, 04:52 PM   #114
89TBIguy
slowly but surely
89TBIguy's Avatar
Trim fenders
Install hitch
Install tow hooks
Plate the frame
Anything else?
By this friday:
Get a hold of RCV for new shafts/ "fix" your chromos
Get trailer, straps, etc
Fill up tank
Gather tools
...Cuz ill be pulling you down there, was workin all weekend and the blazer can't come to me . Reason #4845584954 I cant wait until next years apt with a garage a space for a trailer
Old March 19th, 2013, 04:56 PM   #115
89TBIguy
slowly but surely
89TBIguy's Avatar
Oh I will, she has come a long way but theres always more.
Im glad we have inspired you... what are your future plans for yours?
Old March 19th, 2013, 06:44 PM   #116
bud442
bud442's Avatar
as of right now, get the rear suspension back in(changed over to drop shackle). get the ride height correct, and then need new driveshafts.
installing a full roll cage( I just got delivered).
then hopefully the 6.0l installed.
last but not least, take it out and see what I can break!
Old March 20th, 2013, 01:12 PM   #117
89TBIguy
slowly but surely
89TBIguy's Avatar
Sounds awesome, Where did you get the cage from?
That 6.0 should help you break some stuff
Old March 20th, 2013, 06:58 PM   #118
bud442
bud442's Avatar
here is a link for another forum, I bought it from the guy making the post.
http://blazerforum.com/forum/private...age-kit-76682/
Old March 20th, 2013, 08:45 PM   #119
89TBIguy
slowly but surely
89TBIguy's Avatar
Appreciate it, cant view the pics tho as im not a member. Im just curious to see how it looks cuz in going to a rear taper on mine so the rear-most mounts are gonna have to be angled in to sit on top of the frame rails if that makes sense. Does it look easy to modify?
Old March 21st, 2013, 12:24 PM   #120
Deuling
Sand Slut
Deuling's Avatar
I've got pics from the guy.
Gimme a min I'll post up after I find in my email
Edit: Here you go
Im going to have Shortiron on here build mine.
He did this full vert for his buddy and sent me a few pics.
It will cost me about the same amount to have him build my cage, as the one in the box... But he is like 5 min down the road from me so thats a little different...
Page generated in 0.41555 seconds with 84 queries
