96 Tahoe part out on air bags - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old October 23rd, 2012, 08:33 PM   #1
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Default 96 Tahoe part out on air bags
96 Tahoe, sas'd with a ford radius arm 44 355 gear, stock 10 bolt rear 342, grey leather int, tail gate body (opposed to barn doors). The truck has no motor but dose have trans, case and drive shafts. Has 126k on odo. I have already removed the doors and am also keeping the front fenders and wheels/tires. Every thing else is forsale have a clean clear title on the way right now.
Let me know what you want and ill give you a price
But for rules sakes 250 trans, 150 case, 150 all seats+ center console. 150 front air bags, 100 rear, 200 all four.
beaterk5 is offline   Reply With Quote
Old October 23rd, 2012, 11:29 PM   #2
beaterk5
beaterk5's Avatar
Also forgot will trade for other parts and guns
Old October 26th, 2012, 04:06 PM   #3
Zach4739
2005 Willys
Zach4739's Avatar
does the tcase have the buttom or the lever to engage it.
Zach4739 is offline   Reply With Quote
Old October 28th, 2012, 02:55 PM   #4
beaterk5
beaterk5's Avatar
push button, 243 i belive
Old October 28th, 2012, 04:53 PM   #5
TboneK1500Z28
theres no shifter on the floor. i have a floor shift one at my house i need gone if he doesnt have the one your looking for.
TboneK1500Z28 is offline   Reply With Quote
Old October 28th, 2012, 09:11 PM   #6
Zach4739
2005 Willys
Zach4739's Avatar
well my brothers got a tahoe with the button and the buttons dont work anymore. does the 4x4 ingage with the button? if so how much for the brains of the 4x4
Old October 29th, 2012, 08:45 AM   #7
beaterk5
beaterk5's Avatar
Depends dose he just need the switches or the encoder motor or the thermal actuator or the PCM. If the orange lights don't light up I'd say its the switch, if it just flashes when you press the 4wd button it'd probably be the actuator or encoder motor. Need a little more diagnostics befor you start throwing parts
But more pics of Tahoe ill get some of the back seat when ever I unburry the back seat
Old October 29th, 2012, 09:05 AM   #8
Zach4739
2005 Willys
Zach4739's Avatar
ill do some research and get back to you. the buttons are all lit up and nothing happens when you press them... the used to blink then stopped
Old October 29th, 2012, 09:20 AM   #9
deerebowtie
Unchained
deerebowtie's Avatar
any chance I could get a section of the rear floor?
Old October 29th, 2012, 09:59 AM   #10
TboneK1500Z28
im still interested in the parts mentioned before.
Old October 29th, 2012, 11:20 AM   #11
beaterk5
beaterk5's Avatar
I suppose it would be possible and 10-4 I will work on clearing some stuff out to get at the rear seat and try and figure out how I'm going to get that tailgate open.
Old October 29th, 2012, 11:24 AM   #12
deerebowtie
Unchained
apply battery power and use the button on the rear p-side upper pillar. if that doesn't you could pull the panel and jumper the leads.
Old October 29th, 2012, 11:25 AM   #13
TboneK1500Z28
take off the panel, stick your hand between both sides, have another person help you, and theres little levers you have to push it up farther than youll expect. sometimes only one side comes off so pull the handle and then mess with the levers.
or if it works use his way^
Old October 29th, 2012, 02:19 PM   #14
beaterk5
beaterk5's Avatar
The wiring harnes is intact so ill try the batt way first lol
Old October 31st, 2012, 10:00 PM   #15
04z71kid
is the front converted to 6 lug? if so how much and do you have a pic of it?
04z71kid is offline   Reply With Quote
Old November 5th, 2012, 11:24 AM   #16
beaterk5
beaterk5's Avatar
Yes it is. 150 needs the long side axle shaft(a ford one). I don't have any pics currently but next time I'm by it ill grab a couple for you. It looks like a ford 44 radius arm axle with Chevy knuckles and outers. Has new balljoints too
Old November 9th, 2012, 12:40 AM   #17
Dirthog250r
FORD POWER!!!!!!!!!!!!!!!
Dirthog250r's Avatar
How dus the back axle look can it still fit on a stock truck or?
Dirthog250r is offline   Reply With Quote
Old November 9th, 2012, 08:30 AM   #18
TboneK1500Z28
it says its the stock 10 bolt
Old November 9th, 2012, 11:17 AM   #19
beaterk5
beaterk5's Avatar
Yes I belive it could. It would need the air bag mounts removed from we're the bump stops sit but I don't think any thing else I changed. It looks like its just a piece of square stock u-bolted to the spring perch. Ill be home this weekend and try and get pics for every one
Old November 9th, 2012, 11:22 AM   #20
beaterk5
beaterk5's Avatar
Page generated in 0.45699 seconds with 83 queries
