Help! Front drive shaft for doubler setup - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 23rd, 2012, 08:32 PM   #1
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Default Help! Front drive shaft for doubler setup
Has anyone sourced a stock driveshaft for direct fit on a doubler setup(203/205 ord kit behind th350, dana 60 front, 14b ff rear)?
I have the flange output on my chevy np205. I roughly measured it out to 33-34" flange to center of joint at static load (tires on ground, full weight on front axle). Rough measurement because the 205 isn't installed yet.
I know you can pick up adapter yokes to eliminate the cv joint on the shaft, but was curious if there was a drop in shaft. My stock one is obviously too short, and is worn out to boot.
Hope my spelling and punctuation is better than DEVON. What a turd.
Jake
Sent from my htc evo
The Kernel (46 CJ2a)
Wow, i would lick those...
Old October 23rd, 2012, 08:53 PM   #2
Lousypirate
Whoop Whoop
Might I add that I don't have the coin to have one made.
I can shorten shafts at the family shop, but would prefer something drop in.
Old October 24th, 2012, 03:58 PM   #3
Lousypirate
Whoop Whoop
Ttt
Old October 24th, 2012, 06:36 PM   #4
in2deep
Hole tester
ever think of going to the junk yard with tape mesure and looking there usally have a rack full of shafts
Old October 25th, 2012, 04:16 PM   #5
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
http://www2.dana.com/pdf/J321-CV.PDF
Use the find tool (control F) or go insane. Have fun
Old October 26th, 2012, 06:01 AM   #6
Lousypirate
Whoop Whoop
Thank you, looks like some of the blazer shafts are drop in. too bad they didn't have the trucks in the .pdf
Old October 28th, 2012, 10:30 AM   #7
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
If you don't have the coin then just cut the one you have down.....just about zero dollars into it, if you already have all longer driveshaft!
Old October 29th, 2012, 11:16 AM   #8
Lousypirate
Whoop Whoop
front shaft is too short. rear is too long. cutting down rear to fit.
need new short. trying to get one off of big al, but he hasn't responded after the first couple pm's.
Page generated in 0.30089 seconds with 47 queries
