Husqvarna or Stihl chainsaw?? - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 24th, 2012, 08:09 AM   #61
GearDrive
A little slow
GearDrive's Avatar
Stihl 026 here. I heat with wood and cut 6-8 full cord a year for 25 years. No problems.
GearDrive is offline   Reply With Quote
Old October 24th, 2012, 08:15 AM   #62
Dieselyj
Originally Posted by 1 ton tj on 40's View Post
what type of poulan i need parts for mine?
It is a Poulan Pro 42cc, 18 or 20" bar. You can have it if you need it. It still runs, just wont idle. Repairman says it needs a new carb.
Dieselyj is offline   Reply With Quote
Old October 24th, 2012, 08:16 AM   #63
Dieselyj
Is premium fuel ethanol free???
Old October 24th, 2012, 08:19 AM   #64
kickstand
circling the drain
kickstand's Avatar
No, finding ethanol free fuel in michigan is kinda like finding a virgin on match.com, you can do it, but not consistently.
I wouldn't worry too much about ethanol fuel in your chainsaw (if you buy a new unit) as much as I would in an older saw. The ethanol can be hell on rubber fuel lines and o-rings/seals, etc that it comes in contact with.
As a safety measure if I know my saw is going to sit for more than a week or so I make sure to run it out of fuel when I am done, just to avoid that shit sitting in my saw.
Old October 24th, 2012, 08:21 AM   #65
Padilen
Padilen's Avatar
Not sure but my dealer sells an additive and recommends adding it to premium.
Padilen is offline   Reply With Quote
Old October 24th, 2012, 09:45 AM   #66
bdd1469
bdd
bdd1469's Avatar
Stabil has a product for year round use now,not just for storing over a period of time.I think the only place to get ethonal free gas is in a marina.
Old October 24th, 2012, 10:30 AM   #67
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
most any marina sells "recreational fuel" we changed all of our equipment over to this along with premium stihl oil.
Old October 24th, 2012, 11:12 AM   #68
Jiveturkey3
Jiveturkey3's Avatar
Few points to help out. Ms271 290 291 311 and 391 have a free case promo through dec. stihls "premium" oil is full synthetic. We find it reduces carbon build up greatly (we meaning our dealer staff not stihls claims). Buying a six pack of it as a homeowner not pro guys doubles the warranty on any gas powered handheld. Saws are a normal 1yr 2yrs with oil blower are a normal 2yrs now 4 with oil.
Stihls fuel mix has a stabilizer in it no reason to ad more. Dump any mixed fuel after 2 months. Also the stihl pre mixed stuff is e free but very pricey.
Jiveturkey3 is offline   Reply With Quote
Old October 24th, 2012, 11:16 AM   #69
93trackaddict
93trackaddict's Avatar
Something i have not seen recomended
yet,
Just because they tell you the max bar length for a saw does not mean you need that
I would go with a 290 and 16" bar
Good all around saw
You can cut up to a 32" tree
Smaller more maneuverable
Less teeth to keep charpened
You may want to bump it up to 3/8 chisel chain fot great cutting
The 3/8 chain moves alot of would fast and seems to stay charper longer for me
I own 026/029 stihls with short bars/aggressive chains and love them
Picked up an old homelite 410 with 24" bar for the real big stuff- i use it 6-8 times a year so used made the most sense
If i could only have one saw the 029 as describes would be perfect!
93trackaddict is offline   Reply With Quote
Old October 24th, 2012, 04:01 PM   #70
busyfixin
Balls Deep
busyfixin's Avatar
Good point, usually the big difference between a 16" and 20" bar is that the 20" will be dipped in the dirt more often.
We have a 14" on our 170, a 16", and 20" on the 041's, a 16" & 18" for the 026, and an 18" & 28" for the 044.
Old October 24th, 2012, 04:04 PM   #71
dudekcj7
rev limiter racing
dudekcj7's Avatar
I vote husky love mine and it gets beat starts easy only thing i dont like is the chain tensioner.
dudekcj7 is offline   Reply With Quote
Old October 24th, 2012, 04:19 PM   #72
toolmantim
Go lil yellow Roobicon...
toolmantim's Avatar
Stihl.
Bought one 12 years ago and will buy another if this one ever dies...which I don't expect to happen unless operator error.
I'm compensating for my manhood.
Northwest Ohio Crawlers
toolmantim is offline   Reply With Quote
Old October 24th, 2012, 04:27 PM   #73
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
My dad has an ancient AV-15 Stihl that he finally gave up using a few years ago. Heated his house solely on wood since '77 using that saw. Two stoves always going too, so that's a ton of wood. The newer saws are build even better. Go with a Stihl.
Sent from ma fone
Mulely is offline   Reply With Quote
Old October 24th, 2012, 05:21 PM   #74
I have an MS290, 18" bar, non safety half chisel chains. I like it, starts/runs dependably, and cuts well. If I run 2-3 tanks of gas through it bucking logs, it gets heavy.
But in general, its a decent saw, no complaints. Have never modified it (no muffler modifications), I probably should...
Old October 25th, 2012, 11:35 AM   #75
ayytee
all throttle no tallent
Originally Posted by 92FleXj View Post
That could be all in the various clutch set ups.
Bar length and chain guide depth will also play a major roll
I bet if I put a 16" bar on my 460 magnum it will out rev yours..
Lots of things play a roll in saws and power
Guess i should have specified, This was with my 18" bar and I have one of the smaller saws in my bunch. Not a dis on stihl just something I've noticed.
ayytee is offline   Reply With Quote
Old October 25th, 2012, 02:21 PM   #76
EL BURRO
33's is how I roll
EL BURRO's Avatar
stihl, all the way
EL BURRO is offline   Reply With Quote
Old October 25th, 2012, 06:23 PM   #77
trailtwister
Don't Insult My Stupidity
trailtwister's Avatar
I have trashed both brands of these saws because I made mistake of buying them to small to get job done. That said make sure you buy at a dealer and not a box store and they will guide you to the right size you need. Either brand you will be happy with if doing it right the first time.
trailtwister is offline   Reply With Quote
Old October 25th, 2012, 07:04 PM   #78
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
If you were keeping score it looks like 6 of 10 stihl
2 of ten husky
1 of ten jonsered
The rest are a mix.
Who is going to fully count this.
Supreme Chancellor!
dougstephvoor is offline   Reply With Quote
Old October 25th, 2012, 07:12 PM   #79
92FleXj
stacks stacked on stacks
92FleXj's Avatar
I say hand saw.... A big one
Old October 25th, 2012, 07:29 PM   #80
92FleXj
92FleXj's Avatar
Page generated in 0.36536 seconds with 83 queries
