95 GMC YUKON 2DR QUESTIONS 3in body lift 3in suspension lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2012, 08:13 PM   #1
DEVON
Default 95 GMC YUKON 2DR QUESTIONS 3in body lift 3in suspension lift
hello im new to the lifted 4x4 world an im hooked i have front end problem
my front wheels seem to hop bad going down the rode i was told my control arm bushings im not sure...an can i jus change the bushing or do i have to change to whole arm input would be greatly appreciated
the truck has 3in body lift and 3in suspension lift on 35s
DEVON is offline   Reply With Quote
Old October 23rd, 2012, 07:27 PM   #2
TboneK1500Z28
how bad of a hop? you can press new bushings in.
TboneK1500Z28 is offline   Reply With Quote
Old October 23rd, 2012, 08:12 PM   #3
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
the upper a-arm bushings are probably gone you'd need new ones. When I did mine I used a cut off wheel and a BFH to get the old ones out, and a ball joint press with the bushings in the freezer for a couple hours to get the new ones in.....had to work with the tools I had
Take everything off like your going to put new brakes on, then take off the upper ball joint nut and pop the ball joint out. Then you can remove the two cam bolts on the arm, the bushings are pressed into both ends. You might as well get new cam bolts because your probably going to break one when you try to take them off
You really need to get rid of the torison lift, if it is a real torison lift with differnet keys
Old October 23rd, 2012, 10:24 PM   #4
deerebowtie
Unchained
deerebowtie's Avatar
how noobish to motor vehicles are you? serious question to analyze where to start with tech.
Please refrain from shorthand notation, use complete sentences, and some semblance of progressive thought.
Also, much better attempt in this thread - thus far.
Old October 23rd, 2012, 10:58 PM   #5
TboneK1500Z28
^ directed at me or is there something about the OP i dont know? i just have an issue capitalizing the first letter in a sentence, i know i do that though.
Old October 23rd, 2012, 11:03 PM   #6
Padilen
Padilen's Avatar
Op
Padilen is offline   Reply With Quote
Old October 23rd, 2012, 11:05 PM   #7
deerebowtie
Unchained
the OP - go check his other thread and you'd see what's up for yourself.
Old October 23rd, 2012, 11:33 PM   #8
TboneK1500Z28
That introduction thread needs to come with a bottle of aspirin on the side. My mind felt like it was running a marathon with no punctuation. Maybe hes on speed and has no time for proper English.
Anywho possibly back on topic, Devon please put a little time into your wording, youll get better results. help us help you type thing. Ya dig?
Old October 24th, 2012, 08:23 AM   #9
xjagain
/\ Don't forget to support the lower control arm. Use something appropriate i.e. Jack stand on the frame rail and the jack under the control arm, as that torsion bar is your primary up pressure on your suspension.
xjagain is offline   Reply With Quote
Page generated in 0.39136 seconds with 50 queries
