241-241 doubler - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2012, 07:06 PM   #1
in2deep
Hole tester
Default 241-241 doubler
im collecting parts for my sas on my 88 scsb
i have seached and found some info on the 241-241 doubler but not much in depth, anyone here built one? the two main questions are is there a bearing in the rear of the first case all the plates i have seen dont have anything thing for a bearing. what about not haveing the oil pump any more
Old October 24th, 2012, 02:10 PM   #2
in2deep
Hole tester
cant believe no one have anything to say about this
any one have any experience with doubler
Old October 24th, 2012, 07:21 PM   #3
bigyj
bigyj's Avatar
I run a 231 to Dana 300 d and d machine doubler. No bearing in the plate. You only use the front half of the first case. So no mainshaft to need a bearing. It just uses a stub shaft to go from the first case to the second case. So also no chain to need oil from the oil pump that gets taken out.
bigyj is offline   Reply With Quote
Old October 24th, 2012, 08:43 PM   #4
in2deep
Hole tester
thanks thats what i was looking for
Page generated in 0.20004 seconds with 35 queries
