ford Dana 60 front kingpin - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2012, 10:43 AM   #1
montecarlo33
The Violator
montecarlo33's Avatar
Default ford Dana 60 front kingpin
Im looking for a Early ford 70's style dana 60 kingpin front axle with 4.10 or 4.56 thats in good condition internally. Just seeing whats out there, thanks.
Old October 22nd, 2012, 11:03 AM   #2
boggin-machine
boggin-machine's Avatar
You putting it in the dodge??
Old October 22nd, 2012, 12:10 PM   #3
mfelsk1505
AMSOIL DEALER
mfelsk1505's Avatar
I have an empty housing for $250 if you want to start from scratch.
mfelsk1505 is offline   Reply With Quote
Old October 22nd, 2012, 12:19 PM   #4
montecarlo33
The Violator
thinking about it. Havnt tore it apart yet but got some major clunking going on when in 4wd, very bad when turning (started at the color tour but made it though the day) and I knew the carrier bearings were getting noisey and I believe they finally went(214,000 on axles). By the time I rebuild my dana 60, put in 4.56's(3.55 now w/ 37" tires) and convert to lockouts($1,000 kit) which I want its almost cheaper this way and it cuts down on maintance costs like wheel bearings and such. Plus it gives me a chance to reclock my front axle a bit for the lift thats on it. Gunna pop the cover off this week and see how bad mine is cause all my outers and u joints are nice and tight so its gotta be internal.
put 3,000 miles on this dodge since i bought it and so far ive been though a fuel pump, front wheel bearings, alternator, transmission(still have to replace but works with a shudder) and now axles I believe its gunna be parked until I can figure this all out, got a 96 ZJ that im DD'ing now that i picked up for dirt cheap.
Old October 22nd, 2012, 12:24 PM   #5
montecarlo33
The Violator
will keep this in mind, but im looking for somthing that at least has a gearset and is for the most part assembled and even mounts all taken off already would be nice.
Old October 22nd, 2012, 07:02 PM   #6
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
What year axle are you looking for? 78-79 or 86-91?
Old October 22nd, 2012, 09:24 PM   #7
boggin-machine
ill pm you my number. give me a call i got some info for you that i dont feel like typeing out right now. give me a call tomorrow after noon sometime. if i dont answer ill call you back.
Old October 22nd, 2012, 10:43 PM   #8
montecarlo33
The Violator
Ok, i will would take any serious advise i could get on this axle swap. I am looking for a late 70's style, cause the late 80 style was balljoint and offset diffs from what ive researched online.
Old October 22nd, 2012, 10:48 PM   #9
MilwaukeeF350
Dan
How much would you give for axle out 79 F350 snowfighter. It had king pin dana 60 but not sure on gear but possible 4.10
Old October 23rd, 2012, 07:36 AM   #10
frdtrckmnrich
Actually all ford dana 60's were king pin until 91. The biggest difference is the location of differential. The 86 and up are 3" closer to the drivers side. I have an 88 that i would sell, it has 4.10's and is complete $800
Old October 23rd, 2012, 04:16 PM   #11
montecarlo33
The Violator
Send me some pictures and we can talk. In alpena?
And I will change the heading but I am strictly looking for a late 70's style ford dana 60 because the offset diff on a 80's style wont leave me enough room to remount my longarms and coil buckets/shocks without modification.
Old October 24th, 2012, 08:46 PM   #12
frdtrckmnrich
I have one of those as well. It is also complete came out of a 79. $950
Old October 25th, 2012, 12:11 PM   #13
montecarlo33
The Violator
gears?
Old October 25th, 2012, 12:25 PM   #14
deerebowtie
Unchained
deerebowtie's Avatar
if you have anything to trade, I has a 4.10 and down carrier sitting on the barn floor in EJ that hasn't quite yet been tossed in the scrap pile.
Old October 25th, 2012, 01:59 PM   #15
frdtrckmnrich
I am 90% sure they are 4.10's. I will go check right now.
Yup, 4.10's it is.
Old November 1st, 2012, 10:14 AM   #16
montecarlo33
The Violator
Plans changed. No longer need, my axle wasnt as bad as I thought so im just going to stick with what I got. Thanks to everyone for helping.
Page generated in 0.37988 seconds with 71 queries
