Track bar, getting axle centered. Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2012, 10:26 AM   #1
Trick
94 Zj, 33s and lockers
Trick's Avatar
Default Track bar, getting axle centered. Help
I installed a new front axle on the Grand Cherokee. I have the control bars hooked up and I'm trying top get the track bar hooked up but a cannot get it.
The front suspension is exactly the same as that came off. This axle is a high pinion out of a Cherokee. Everything should line up and go together but I cannot get this axle centered.
I tried putting the truck on the ground turning the wheel and putting a ratchet strap on the bumper trying to pull it over as much as possible the closest I can get it is within an inch of the bolt hole lining up. I need it to come in more but can't get it.
I could try and make the track bar longer but its kinda seized at the adjuster right not. I'm also thinking it shouldn't need to be adjusted.
Another question do you think I could drive this thing 200 yards without a track bar? I'm trying to get it closer to my house so I can do more work to it but this track bar is killing me.
Trick is offline   Reply With Quote
Old October 21st, 2012, 10:27 AM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
yes you can drive it very slow and take it easy, i always use the put it on the ground and turn the wheels trick. you must have something binding.
Old October 21st, 2012, 12:34 PM   #3
Trick
Trick's Avatar
cool ok well i got it in the garage. Ill look for something binding next time i get at it.
Page generated in 0.22644 seconds with 32 queries
