dana 44 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2012, 12:38 PM   #1
kaotikblazer
Default dana 44 help
hey yall i recently purchased a set of axles to do a solid axle swap on my 98 blazer and traded my way in to a dana 44-50f and a dana 60 8lug axles..only problem im having is identifying the front axle, well what its out of.
i have the bom numbers and have tried the dana site to try and identify it but no luck. i need to find out what its fron cause its missing the rotors and calipers and i need to get wheel studs for it ,any help is greatly apprecieated and thank you ahead of time for your input..
the bom number is 603445-8
kaotikblazer is offline   Reply With Quote
Old October 21st, 2012, 01:38 PM   #2
kaotikblazer
if theirs any more info needed to help me identify this axle i will post what i know about it or what said pictures are needed. i think its pre 79 dana and thats why the search on the dana site isnt working, if some one has the pre 79 bom numbers i would greatly apprecieate it ir if some one can run them for me and find this info i would apprecieate it.
Old October 21st, 2012, 01:56 PM   #3
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I can only assume that it has leaf spring perches? Do you know the wheel to wheel mounting width? High Pinion?
Old October 21st, 2012, 05:44 PM   #4
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Doesn't matter.
Throw away that front axle and find a 60. You can thank me latter
Old October 21st, 2012, 05:58 PM   #5
itselliott
itselliott's Avatar
http://www2.dana.com/expertforms/deabill.aspx
BOM comes up empty here
but the Jeep and Chry lists are the only ones beginning with 603
Old October 22nd, 2012, 05:36 PM   #6
kaotikblazer
i would love to grab a dana 60 but expenses dont allow me to right now..ill have to get wheel mount measurements and all later when im at the shop..and as far as only jeep and chry starting with 603 the pre 79 chevy/gm and all do, i finally got ahold of them and still could not find the bom numbers even looked through all the 603s from chevy dodge ford jeep ihc all of them and could still not find them..il post pix when i get to the shop..yes its a leaf spring set up with 4.10 gears passenger side drop
Old October 22nd, 2012, 05:39 PM   #7
kaotikblazer
the closest bom i could find to mine was a 603455-8 for a 74-75 k20 3/4 ton pick up & station wagon on truck chassis..is their any other set of number or something i might beable to go by to find out what i need? thanck yall for the imput all help is greatly apprecieated.
on a second thought is their any caliper/rotor from a diff year dana 44 that i can use so i dont have to find out the specific make/model of what it came out of..
Old October 22nd, 2012, 06:06 PM   #8
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Please DO NOT run a 44 in your blazer, even if it is a S series it will still weigh over 5k lbs, if its a full sized it will be even more. Way to much weight for a 44. I too thought I couldn't afford a 60 at the time and have certainly paid for it in the long run. Even if you polish your 44 your still going to run into problems and break almost every time you wheel.
You've been warned
Old October 22nd, 2012, 06:14 PM   #9
kaotikblazer
its not going to be wheeled any time soon still have to track down a transfer case.
jus need it in their for a couple months till i have the money to buy a 60 cheapest one ive found was 700 bucks and that was the only one i could find.
i just need to get my ride back running this not having a vehicle is killing me.
Old October 22nd, 2012, 07:52 PM   #10
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
What transfer case do you have?
Old October 23rd, 2012, 07:26 AM   #11
kaotikblazer
at the moment i do not have a transfer case its still 2wd.
Old October 23rd, 2012, 10:26 PM   #12
kaotikblazer
finally found out exactly wht the axle is from 75 k20 3/4 ton..now to go get some brakes..ill post some pix probably thursday nite or fri.
Old December 9th, 2012, 12:54 PM   #13
kaotikblazer
recently finished getting the front axle installed in my blazer and when i went to put a load on the front end the shackles went flat( ill post pix in a minute) its kinda hard to explain. when i set the the hanger tobegin with with out any load i had them almost straight up and down so that when i put the motor and trans back in it would sink and give it about a 10 degree foward slant on it, if i jack the body up the shackle pop back out and are fine till it again gets aload and the go back flat, i believe i shoulda put more of a rearward slant on the shackles but not sure. like i said i will post pix in a minute to show exaclty what im talking about. all help and opinions are greatly apprecieated.
Old December 9th, 2012, 02:08 PM   #14
kaotikblazer
heres the pictures..the side thats compressed is the driver side and the side that slightly ipen is the passenger side thats droped down in a whole. but once back on flat ground it will compress like the other..
Old December 9th, 2012, 02:09 PM   #15
kaotikblazer
note the rear hangers are jus tacked..not finished product was testing everything out when i ran into this problem.
Old December 9th, 2012, 03:06 PM   #16
in2deep
Hole tester
move the hangers back
Old December 9th, 2012, 03:29 PM   #17
Dylan
Dylan's Avatar
without load the shackles should have been puling forward, not straight up and down. I would mark where the spring eye bolt is in vertical relation to the frame now and then move the shackle eye bolt to just before that spot.
Old December 9th, 2012, 06:12 PM   #18
kaotikblazer
i was thinking that was my problem, jus have never seen that happen to before. guess ill be moving them when i get a chance..ill post some pix of it tomorrow
Page generated in 0.38673 seconds with 78 queries
