Thread Tools
Old October 18th, 2012, 09:06 PM   #1
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
1999 wont start FIXED THANKS
i just picked up this cherokee and can not get it to start with key. if i turn the key on and jump the starter it fires right up, i can hear relay click when i turn key to start but nothing. also tried in neutral. it has been setting for awhile. any ideas would b great.
hman1991 is offline   Reply With Quote
Old October 18th, 2012, 10:05 PM   #2
mrclean
Silver Lake
mrclean's Avatar
Sounds like a dirty neutral safety switch. There is a write up about how to take it apart and clean it if you search online.
mrclean is offline   Reply With Quote
Old October 19th, 2012, 02:06 PM   #3
chriszildjian17
chriszildjian17's Avatar
Those switches are pricey to. just had to buy one. the were like 300. it was for a friend but his cherokee did the same thing. switch fixed it
chriszildjian17 is offline   Reply With Quote
Old October 19th, 2012, 03:34 PM   #4
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
on my 95, i had to rock it back and forth in park a few times, then it fired.
SlayerXJ is offline   Reply With Quote
Old October 19th, 2012, 05:48 PM   #5
98ZJ318
RIP 2-15 12:20 AM
98ZJ318's Avatar
Thats the NSS. Mine gives me all sorts of problems, usually just have to roll it threw the gears and it'll fire right up in N. Some people get lucky and can clean the contact points, while others get F'd and it'll break. I need to do this but don't have the ambition.
98ZJ318 is offline   Reply With Quote
Old October 20th, 2012, 02:27 PM   #6
mikeb2275
mikeb2275's Avatar
see if you can find the relay for the starter and make sure it is clicking when you turn the key on if it does then it sounds like the starter solenoid
mikeb2275 is offline   Reply With Quote
Old October 21st, 2012, 02:40 PM   #7
hman1991
hman1991's Avatar
Alright I bypassed the nss first. No luck. Replaced it second. No luck. There is power going out of the ignition and an hear click of a relay inside on the fuse block. Waiting on someone to come home to varify the one under the hood. I had taken the starter to AutoZone and it passed, also if I jump the terminals on the starter relay it also turns over. I also tried replacing the relay.
Old October 21st, 2012, 03:15 PM   #8
go1lum
Just an idea, broken wire somewhere?
go1lum is offline   Reply With Quote
Old October 21st, 2012, 03:22 PM   #9
hman1991
hman1991's Avatar
Problem solved. Wasnt getting power to relay. Had a broken wire at firewall. Also for the guys that are having problems with yohr nss. To bypass just the neutral start without messing with your trans. Just connect the 2 black wires togather. I did it on the nss side of the grey plug under the hood. Thanks for everyones input.
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.13626 seconds with 28 queries
