Possibly bent inner C's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 16th, 2012, 10:29 PM   #1
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Default Possibly bent inner C's
The front tires leanin in up top and I kinda think I have a bent Upper C on both sides. Maybe I'm wrong. Ball joints seem to be fine. If it helps, it is a Dana 30. Anybody have this problem? I know the inner C's are cast and I know heating and bending cast isn't recommended, but is there a way to maybe straighten it out? Straighten it and get a gusset kit? Any help would be appreciated. Please and thanks
Old October 16th, 2012, 10:33 PM   #2
boggin-machine
boggin-machine's Avatar
Dana 30s are throw away axles. Junk it and bolt another in after you truss it
Old October 16th, 2012, 10:37 PM   #3
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Believe me I know they are junk axles and probably a dime a dozen. I just need it to last me until spring until I can get a truck and park it. The plan is D60/14b. I just need to know if it's something I should really worry about or if it'll last me until about March.
Old October 16th, 2012, 10:39 PM   #4
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
havy you tried to pull the inner axles out, if they bind and you have a hell of a time getting them out, something is bent.
Proceed with it until replacement.
Supreme Chancellor!
dougstephvoor is offline   Reply With Quote
Old October 16th, 2012, 10:40 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I have a empty tj housing
H.o.r.e
Old October 16th, 2012, 10:50 PM   #6
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
I'll give that a try this weekend. Thanks for the tip.
Scott I'll also keep that in mind about the empty housing. Thanks
Old October 16th, 2012, 10:51 PM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
If you have to drive it I would swap in another one and truss it.
Old October 16th, 2012, 10:52 PM   #8
bigbchevy
missmrgreenagain
bigbchevy's Avatar
This cause you are going to fukc up your tires if it is bent
H.o.r.e
Old October 16th, 2012, 10:58 PM   #9
Tab
Tab's Avatar
How are the unit bearings? A little ball joint slop added with a little unit bearing slop can add up to a few degrees of camber. When I still ran a 30 I had a badly worn bearings and it was very noticeable in the tire lean.
Old October 16th, 2012, 11:02 PM   #10
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
I realize that. I need to check and make sure the axle tube isn't bent. How much would you want for that housing Scott?
Old October 16th, 2012, 11:03 PM   #11
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
I replaced the driver side bearing about 3 months ago when I put my crossover steering kit on. So fairly new on that one and I haven't touched the passenger side. But both tires lean.
Old October 16th, 2012, 11:08 PM   #12
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Cheap
H.o.r.e
Old October 16th, 2012, 11:10 PM   #13
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
I'll let you know if I decide to do that. I don't really have time to do an axle swap but if it's my last option I gotta do it. Thanks
Page generated in 0.24229 seconds with 62 queries
