DIY Tire Balancing VIDEO using airsoft or BB's without unmounting your tires! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 16th, 2012, 03:59 PM   #1
ryanclimbs
werocker
ryanclimbs's Avatar
Default DIY Tire Balancing VIDEO using airsoft or BB's without unmounting your tires!
Just balanced my tires using airsoft... works well if your tires are reasonably balanced to start with... if they may need more than 10-12OZ each don't expect this to work too well!
http://www.youtube.com/watch?v=FMOZl...ature=youtu.be
JK-U Currie D60 RJIII's w/ARB's | Teraflex LCG | Mud Grappler 40x15.50x20's on Spyderlocks | Warn Dualforce 12K WINCH
Custom cage-rockers-body armour | WOODY's | passport plus lincoln on-board welder | S&W airlite 44 under the seat
ryanclimbs is offline   Reply With Quote
Old October 16th, 2012, 04:53 PM   #2
mschaffer66
mschaffer66's Avatar
I'm an idiot, but...
For those without monster valves once you pull out your valve stem wouldn't you need to break the tire down anyway to reinstall it?
Old October 16th, 2012, 05:10 PM   #3
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Pull the core Mschaffer
Mr. Beefy is online now   Reply With Quote
Old October 16th, 2012, 05:29 PM   #4
Wheelman
Extreme Mudder
Wheelman's Avatar
I have used dyna beads on 36x13.5x16 And they worked great. I will defiantly use them on all my aggressive tires.
They are small enough to go thru the valve stem after you pull the core.
http://www.innovativebalancing.com/index.php
Wheelman is offline   Reply With Quote
Old October 16th, 2012, 07:01 PM   #5
mschaffer66
And feed the 1000+ bb's into each wheel one at a time?
Edit:
I had to go see if it was even possible.
Unless there is some magic trick it isn't going to happen.
However that is one of larger BB's, so maybe the ones that are a little smaller may fit. Even if it was half the size I think that may make for a very mind numbing day or 12.
Old October 16th, 2012, 07:03 PM   #6
REXG
REXG's Avatar
Same thing as balancing beads in theory it should work
REXG is offline   Reply With Quote
Old October 16th, 2012, 07:07 PM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Yupp
Old October 16th, 2012, 07:40 PM   #8
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I put them in at the same time I was mounting the tires. Just dropped them in before I set the bead.
Old October 16th, 2012, 10:42 PM   #9
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Put airsoft bb's in my steel DIY beadlocks with 39.5 IROK tires. Balanced them out perfect. Use to have horrible death wobble without them. I think I did 13 oz? I used the chart online.
Old October 17th, 2012, 01:13 AM   #10
rammanriley
rammanriley's Avatar
hmmm. I'll have to give this a shot.
rammanriley is offline   Reply With Quote
Old October 17th, 2012, 04:30 AM   #11
curbdog17
Mini Van
curbdog17's Avatar
Just like anal beads, One at a time.
Old October 19th, 2012, 11:48 AM   #12
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
Worked great for me, I put them in while I was mounting the tires.
Blue XJ is offline   Reply With Quote
Page generated in 0.35140 seconds with 59 queries
