weird driveline noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2012, 05:32 PM   #1
oOEVIDENCEOo
oOEVIDENCEOo's Avatar
Default weird driveline noise
its from 25 to 50 mph and its when im in the gas its like a woooo noise let off the gas and it goes away so it is when it has a load on it is this pinion bearing noise? its a 2000 jeep cherokee 8.25 rear axle to it sounds like its is coming from the rear end checked drive shaft that seems to be fine its has a sye with a tom woods driveshaft fairly new so dont think it could be the u joints any help would be great ty
oOEVIDENCEOo is offline   Reply With Quote
Old October 16th, 2012, 01:24 PM   #2
oOEVIDENCEOo
anyone?
Old October 16th, 2012, 01:52 PM   #3
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Wooo could be any number of things. Rear end to vacume leak. Wheel bearings dont change from rpm. What happens when you slalomn down the road under power.
tcxtreme1000 is offline   Reply With Quote
Old October 16th, 2012, 06:47 PM   #4
oOEVIDENCEOo
nothing its just when u apply the gas and def not a vacume leak def in the driveline it sounds like it is comeing from the rear end
Old October 16th, 2012, 10:32 PM   #5
bdd1469
bdd
bdd1469's Avatar
Sounds like pinion noise to me.Grab the rear yoke and see if it has any play up n down.Is the pinion seal leaking? That could be a sign of bad pinion bearings,unless you are in the mud a lot. You can try to snug the pinion nut up just a little and see if the noise changes,be carefull dont over torque your crush sleeve.
Old October 16th, 2012, 10:38 PM   #6
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Pinion bearings. The pinion nut probably isn't torqued to the right spec. Their tricky if you don't do them right. I didn't do one right and had the same noise. Few weeks after I started hearing the howl/ whine, I let off the gas and BOOM blew the bearings and ate the teeth on the pinion right up.
Old October 16th, 2012, 10:42 PM   #7
tom77cj5
tom77cj5's Avatar
Sounds like pinion bearings. One of my trucks did that last week. Pinion bearing was going out.
Old October 16th, 2012, 11:39 PM   #8
oOEVIDENCEOo
ya it started after the i put the lift on it and it didnt have the sye yet theres no play in it but i did have to change the yoke and when i did that it went away for like a week now im useing it as a dd and the noise is really annoying im thinking of just getting another axle and just swap it out cause everyone wants alot to change the bearing
Old October 16th, 2012, 11:40 PM   #9
oOEVIDENCEOo
anyone know what the right torque is?
Old November 28th, 2012, 11:03 PM   #10
gearedfather
tighten the pinion nut 1 flat and see if it gets better.
gearedfather is offline   Reply With Quote
Old December 1st, 2012, 09:10 AM   #11
littletrucker
I'd hit that
littletrucker's Avatar
Proper pinion angle? Did you adjust it after the lift? After you put the cv shaft in? (I assume its a cv style shaft)
Cv style need a diffrent working angle than your reg. driveshaft.
Page generated in 0.32564 seconds with 56 queries
