cutting bushings/sleeves - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2012, 09:51 AM   #1
turnofftheradio
Default cutting bushings/sleeves
I have some really stuck cradle bushings I need to chop out. basically cutting through the sleeve and bolt. I have a sawsall. My standard metal blades turned into a butter knife in short order.
I hear the black carbide tungsten ones will work, but nobody around here seems to sell them
anyone used the off brand home depot "diablo" ones (red)? or know a place I can get the black ones locally? (dearborn)
I'd like to just get some blades not order them so I can get these chopped out.
turnofftheradio is offline   Reply With Quote
Old October 15th, 2012, 09:59 AM   #2
Don't run your saw wide open. Use cutting oil. Take your time.
BTW, what's a cradle bushing?
Old October 15th, 2012, 10:10 AM   #3
turnofftheradio
much like any other bushing, but it holds my engine cradle in... bushing between two ears, bolt through. have access to both sides. I tried splitting the sleeve, and did at the seam, but the bolts not going anywhere. the bushings are going to be replaced with poly or aluminum.
its 2wd
Old October 15th, 2012, 10:44 AM   #4
If you're trying to get the bolt out use an air chisel.
Old October 15th, 2012, 10:55 AM   #5
turnofftheradio
no air available...
I could never get one in to hit the bolt through. possibly to pull it under the head, but I just dont have that option.
cutting them off is the easiest option, I have a recrip. saw. If it is useless, I can use a cutoff wheel borrowed, but the saw would be less smoke from the bushing, and less sparks/cutoff wheels in my eyes, and I have it.
maybe I was cutting too fast for my blades.
Old October 15th, 2012, 02:26 PM   #6
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
agreed... Some times slow is faster...
Old October 15th, 2012, 02:38 PM   #7
JeepInABox
In too deep
JeepInABox's Avatar
Torch the bolt then hit it with brass drift. Try not to burn your garage down.
Old October 15th, 2012, 02:40 PM   #8
fsumotorhead
N8KVB
fsumotorhead's Avatar
I feel this lesson is almost a right of passage to learn.
Once you slow down the saw/drill, the blades cut better, faster, and last longer.
Old October 15th, 2012, 07:21 PM   #9
turnofftheradio
Well, I had one last new "torch" blade. I used it on the slowest speed possible. I got nowhere. No matter what, that blade will not cut the sleeve. It does cut the bolt though. I did manage to get one side out with impact wrench abuse, mapp and a hammer. So only one more to go.
Old October 16th, 2012, 07:35 AM   #10
turnofftheradio
what I needed to do was bs with you guys while the pb blaster did its job. I went back to it last night and got them both out.
thanks!
Old October 16th, 2012, 08:08 AM   #11
boggin-machine
boggin-machine's Avatar
Take the board off of the jackstands!!
Old October 16th, 2012, 09:26 AM   #12
turnofftheradio
whats wrong with my board on jackstands? its the very best way to pull fiero engine without a lift, if you are not disturbed by nearly vertical cars
Page generated in 0.32152 seconds with 59 queries
