TJ 3" lift now death wobble - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2012, 06:22 AM   #1
mojave01x2
mojave01x2's Avatar
Default TJ 3" lift now death wobble
My 2004 tj drove great but I had to have a lift. Being a cheap ass I bought used coils and rear track bar locator installed them, lowered the transfer case, spaced the shocks, for th front track bar I drilled a new hole 5/8" from the original. Worked great for a week or so. Then deathwobble, so I drilled out the bushing and hole for a larger bolt was a little better, so I replaced the track bar bushing with a poly bushing, but I still have death wobble.
Im thinking my next step should be an adjustable track bar, but give me some suggestions.
mojave01x2 is offline   Reply With Quote
Old October 15th, 2012, 06:41 AM   #2
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Check all the bushing, tie rods, did you swap for a drop pitman, New lower arms or justa spring swap?
tcxtreme1000 is offline   Reply With Quote
Old October 15th, 2012, 06:43 AM   #3
mojave01x2
mojave01x2's Avatar
Just a spring swap, all the kits i looked at for 3" didnt have lower arms.
Old October 15th, 2012, 07:18 AM   #4
babyjp95
average guy
babyjp95's Avatar
check your steering stabilizer!
babyjp95 is offline   Reply With Quote
Old October 15th, 2012, 08:23 AM   #5
joe_jeep
welfare wheeler
joe_jeep's Avatar
get under it. have someone steer it left to right and back many times. look for play anywhere. something is loose. also get and alignment, changing the springs and not the arms is gonna mess with angles. re-balance the tires.
Old October 15th, 2012, 08:31 AM   #6
Toivo
Feel lucky?
Toivo's Avatar
What joejeep said. Many people like to claim steering stabilizer when in fact the steering stabilizer is nothing more than a band aid for steering issues. Check torque specifications on all your front end bolts with a torque wrench. Impact or Breaker bar tight is too tight, if you are worried about bolts loosening use loc tite, but tighten the bolts to factory torque specification and get an alignment.
Old October 15th, 2012, 08:37 AM   #7
mojave01x2
mojave01x2's Avatar
Ok guess im looking for factory specs cause I definatly overtightened everything, and I knew an alignment is a requirement so that is moved to the top of my to do list.
Old October 15th, 2012, 01:34 PM   #8
Dylan
Dylan's Avatar
get some caster cam bolts or make your own. set your toe to 1/16-1/8" in and max your caster with those slots on the lower axle mount.
Old October 15th, 2012, 03:27 PM   #9
Paul04TJ
Small, but talented
Paul04TJ's Avatar
2X on the Caster
Paul04TJ is offline   Reply With Quote
Old October 15th, 2012, 08:42 PM   #10
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
three times my trac bar failed at the upper connection, it was very noticable when some one shucks the steering back and forth while you look under neith.
Supreme Chancellor!
dougstephvoor is offline   Reply With Quote
Old October 15th, 2012, 09:34 PM   #11
newdodge
jeep life
newdodge's Avatar
Front tires can do that too
newdodge is offline   Reply With Quote
Old October 17th, 2012, 04:00 PM   #12
Mr.Green
I can levitate!
Mr.Green's Avatar
Sounds like the exact same thing I ran into. 3" springs, then death wobble. It is caused by some compliant steering parts, but the reduction in caster from the 3" lift is what made it a problem. Caster adjustment first.
Old October 18th, 2012, 05:14 AM   #13
mojave01x2
mojave01x2's Avatar
Found a bad tie rod end on the pitman arm, replaced it and its pretty good now. Still have an alignment scheduled for saturday. But now I need some 33" tires.
Old October 18th, 2012, 05:43 AM   #14
Dylan
Dylan's Avatar
unless you buy caster cams before saturday, they will just set your toe because thats all that is adjustable on a TJ. Won't fix anything.
Old October 18th, 2012, 06:48 AM   #15
mojave01x2
mojave01x2's Avatar
Ok where do i find some caster cams?
Old October 18th, 2012, 07:45 AM   #16
joe_jeep
welfare wheeler
joe_jeep's Avatar
local parts store can get them. moog offers them. most good 4wd shops will have them.
moog calls them cam bolts.
Old October 18th, 2012, 08:02 AM   #17
mojave01x2
mojave01x2's Avatar
Found the kit #k100047 But cant get it locally til monday. Guess ill postpone my alignment.
Old October 18th, 2012, 11:19 AM   #18
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
What he said, I had the same issue after I installed the lift and it turned out my new front adj track bar and the bracket were slightly loose which cauaed a wobble. Make sure everything is super tight. Have a friend move the wheel back and forth an look, you will find your problem
Catnip 0_o is offline   Reply With Quote
Old October 18th, 2012, 11:37 PM   #19
bdd1469
bdd
bdd1469's Avatar
Must be luck and loose tolerances if you need caster shims,or not.I have 2.5 rc springs and 2.25 terraflex boost blocks and my junk drives great with a tape measure allighnment.I drive it daily on the highway and have 65,000 miles on my km2s.
I have had death wobble twice and both times it was a junk track bar.And there was that time I rebeaded a tire with a bunch of snow in it,but that doesnt count.
I recomend adjustable arms or cams,but I have had no problems without them.
Page generated in 0.33068 seconds with 80 queries
