32' Tri-axle Trailer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 14th, 2012, 07:34 PM   #1
92xjr
build it to break it!
92xjr's Avatar
Default 32' Tri-axle Trailer
32' tri-axle trailer with 26' of deck. Trailer has fold down ramps, LED lights, storage compartment up front, multiple tie down points, and a heavy duty jack. Deck is in good shape. I used this trailer for several years hauling 2 xj's. I no longer need to haul 2 at a time so I am selling this one and am in the market for a 16'-18' tandem trailer.
$2000 OBO
92xjr is offline   Reply With Quote
Old October 14th, 2012, 07:51 PM   #2
Mobile home axles. Pic is small on my phone. Brakes on the axles?
Old October 14th, 2012, 09:35 PM   #3
92xjr
92xjr's Avatar
yes mobile home axles, there are brakes on 2 axles, neither of which are wired.
Old October 14th, 2012, 09:50 PM   #4
1 ton tj on 40's
1 ton tj on 40's's Avatar
what i i'm looking for pm now
Old October 16th, 2012, 08:32 PM   #5
1 ton tj on 40's
free bump was going to but it but found one just down the road today
Old October 17th, 2012, 07:56 AM   #6
buildingup
What shape are the tires in? Tows straight I assume? Whats the trailer rated for? Weight of trailer? Is everything needed for the brakes on the trailer or some items on the trailer already? Any pictures with the two XJ's on the trailer?
Sent from my DROIDX using Tapatalk 2
buildingup is offline   Reply With Quote
Old October 17th, 2012, 10:22 AM   #7
Do you have a title for the trailer......Interested in trading for a 18" 2007 Suretrac with a steel deck?
Also what size ball is it?
Old October 17th, 2012, 10:09 PM   #8
92xjr
92xjr's Avatar
5 tires are good one is low on tread, trailer tows straight down the road, it has 3 5500# axles, it weighed in right around 2500lbs. The brakes are not hooked up, I do not know if they need anything else or not I have not looked at them.
Old October 17th, 2012, 10:19 PM   #9
92xjr
92xjr's Avatar
I do not have a title for the trailer, when I got the trailer weighed the ticked read just under 2500lbs. so I did not need to get a title. It should still weigh in that same ball park.
I am sorry I did not mention the ball size, it is a 2 5/16" ball
I am interested in trading, do you have any pics?
Old October 20th, 2012, 08:57 AM   #10
2trackr
Deck width?
2trackr is offline   Reply With Quote
Old October 20th, 2012, 01:47 PM   #11
No title is kinda a killer for me, bump for ya GLWS
Old October 20th, 2012, 04:41 PM   #12
92xjr
92xjr's Avatar
Originally Posted by 2trackr View Post
Deck width?
The deck is 78" and it measures 81" between the fenders
Old October 20th, 2012, 04:57 PM   #13
Grassman
2jz specialist
Grassman's Avatar
did this used to be a goose neck? why are the axles so far back?
Old October 20th, 2012, 05:03 PM   #14
I think mobile home axles are 5500#.
Old October 21st, 2012, 05:50 PM   #15
92xjr
92xjr's Avatar
I don't think it used to be a goose neck, I am not sure why the axles are set so far back.
They are mobile home axles, thank you for the correction!
Old October 21st, 2012, 07:32 PM   #16
buildingup
How hard is it to register a trailer without a title?
Old October 21st, 2012, 08:23 PM   #17
1 ton tj on 40's
my mom works for the sos an she tolled me get it weigh an take the slip to sos thats what i have to do with the trailer i just picked up. under 2,500 lb $75 over that is $200
Old October 21st, 2012, 08:38 PM   #18
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
This....trailers this small dont have titles, just registrations
Old October 22nd, 2012, 02:54 PM   #19
tonka toy
It's got a HEMI!
tonka toy's Avatar
Make sure you tell the SOS that you built the trailer and the materials used in building the trailer you had laying around. If you don't go that route you will have to pay sales tax.
Always missed, Never forgotten
FullSize4Life
08' 4door JK 5.7 hemi, auto, atlas and tons
2012 F350 6.7 PSD CC shortbox
tonka toy is offline   Reply With Quote
Old October 22nd, 2012, 08:29 PM   #20
92xjr
92xjr's Avatar
In response to all the recent posts: Thank you for your input on the "title" issue. The reason it does not have a title is because when I had it weighed it was not heavy enough to require a title. Therefore I chose to go the cheaper route and just pay the $75 to register it as opposed to paying $200 for a title. I am sure that if someone wanted to title it the SOS would not have a problem with it.
Once again thanks for your input.
Page generated in 0.35891 seconds with 83 queries
